OT: Rode the trusty ole Honda 350 Scrambler today - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!Ontario TourismHonda Powersports
Old 10-13-2005, 12:30 AM   #1 (permalink)
I have the pipes off the TBS for making a custom 3-1 system, so rode the Honda today -- what a POS, can't believe I used to idolize that bike. It's still in good shape, but feels like a toy, can't wait to finish the TBS & get it back on the road again. For anyone contemplating the new Triumph Scrambler: "nostalgia isn't what it used to be"
The 3-1 project is going well. I finally got the used Ebay 99 Adventurer pipes from the seller, took a long time to get here. They are nearly identical to the 04 TBS pipes except they don't have the cross-over and they exit at a different angle. Other than that, they are the identical length and diameter as the TBS pipes.
Anyone have any thoughts about opening up the diameter of the restrictor at the input end of the pipes? They each have a stout weld bead that reduces the pipe i.d. by quite a bit, I'm sure it's an intentional design detail for better scavenging and increased exhaust velocity as it exits the head, but they have an irregular profile, not at all round. It's easy to open them up with a die grinder & profile the weld a bit smoother.
I'll post pic's as the project progresses, finally got my TIG welder working again & need to do a few practice beads. The existing Adventurer pipes are actually stainless steel and will polish nicely, so if I can grind & buff the welds good enough, it won't look like a Frankenstein/kludge job. I ended up bending and cutting & splicing the pipe for cyl. #1 so it can tuck behind #2 & #3 pipes so all 3 are quasi-equal length. I'm trying to route them so they clear the oil filter. I'm going to have to do some more bending so they don't stick too far out to the right, as it is now, the collector is going to end up directly under the brake lever and I don't want them ever to be a restriction for the rear brake application.
donco
'04 TBS
"Your dog is so ugly, other dogs sniff his face by mistake"
donco is offline   Reply With Quote
Old 10-13-2005, 12:40 AM   #2 (permalink)
jimmyj900's Avatar
I suspect that ugly big weld is intended to function as an anti-reversion step to reduce the effect of exhaust pulses reflected through the system and back into the exhaust valve.
Either that or it's just really cra*ppy construction! :wink:
The problem is that the location of that step will cause a lot of turbulence at the exit of the exhaust port and I figure that it's more of a problem than a benefit with the TOR mufflers.
Removing that weld on my 'to do' list...
Jim
Rode with an R1 today kc5deb Biker Hang-Out 17 07-30-2007 11:35 PM
Rode me a Tiger today! HGaither Tiger Chat 10 02-05-2007 09:56 PM
RODE THE NEW TIGER TODAY doodledog Biker Hang-Out 6 02-03-2007 03:16 PM
Rode New Bike Today! Bob_N Twins Talk 27 12-26-2005 11:48 AM
