Even the cheapie versions of current style chrome plated click-stop torque wrenches have n-m on one side of the scale settings and in-lb (or ft-lb) on the other side. To answer your question, torque is torque and the units convert directly from one system to the next so keep doing what you used to do to convert as required when you need to.
I agree with Bob's reply about getting a good quality one. I bought a cheapie from Harbor Freight & it's way off, it clicks off at least 5 to 10 ft-lbs higher than what it's set at and is a risk for breaking/stripping, or overtightening bolts, I should throw it away & get a good one. The lever type is a bit safer in that respect as long as they go back to zero without a torque applied. The click-stop ones make you go by faith unless you have a means to calibrate it.
donco
'04 TBS
"Your dog is so ugly, other dogs sniff his face by mistake"
