Tank Frame rubbing - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-12-2005, 03:50 AM   #1 (permalink)
Took the petrol tank off the other day to check the cooling system and noticed that the lower edges of the 'U' shaped front tank locating brackets had eaten into the frame tubes on both sides. (The rubbers that fit into these brackets look new) It appears these brackets are too wide, so trimmed them back with the trusty angle grinder. Apart from the damage, this metal on metal rubbing could cause some vibration or noise. The bike is an Adventurer and has less than 10K on it.
Anyone else had this problem? What sort of paint is best to touch up the powder coated finish?
BillBo is offline   Reply With Quote
Speedo cable rubbing on header. tba-golfer Twins Talk 10 06-26-2007 08:29 AM
Chain Rubbing On S4 Swingarm,,,, xsquiggy Triumph SuperSports 12 04-26-2007 09:30 AM
When stator is rubbing against rotor... GulfCoastDave Classic, Vintage & Veteran 4 07-23-2006 03:36 PM
Caliper rubbing, part 2 bigred900 Hinckley Classic Triples 4 07-18-2006 03:01 PM
caliper rubbing question! bigred900 Hinckley Classic Triples 9 07-13-2006 10:06 PM
