newbie carb question - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearOntario TourismMotorcycle.com Classifieds!Honda Powersports Motorcycle.com
Old 10-11-2005, 01:42 PM   #1 (permalink)
I dug into my mikuni carbs last night and from what I could see through the eyeglass the pilot was marked with what looks like "EJ40". Does this mean anything to anyone? Also is there a measurment to determine main jet size?
pmillica is offline   Reply With Quote
Old 10-11-2005, 02:13 PM   #2 (permalink)
Spooner's Avatar
On the Mikunis the pilot is 40 and the main is 90, if everything is stock that is.
S.P.O.O.N.E.R.
Huh?
Speedy MattHilda & Thunderasaki
Spooner is offline   Reply With Quote
Old 10-11-2005, 02:19 PM   #3 (permalink)
Slinky's Avatar
The main jets should be stamped with the size, either on the face or on the side of the head.
A 90 main jet means that the hole is .90mm in diameter.
Old 10-11-2005, 02:24 PM   #4 (permalink)
Thanks for the info. I'm in the process of converting to three uni-filters. From what I've read, #130 main jet seems to be a good choice. Would you agree with this? In addition I want to check my valve clearance. Got any sources for shims?
Old 10-11-2005, 02:31 PM   #5 (permalink)
Spooner's Avatar
There's a guy here who's gone the pod filter way...his name is BigVinny.
Check out this thread for an abundance of info: Airbox...sometimes I wish I had a Harley :upthumb:
Good luck!
[ This message was edited by: Spooner on 2005-10-11 12:56 ]
S.P.O.O.N.E.R.
Huh?
Old 10-11-2005, 02:54 PM   #6 (permalink)
Favourite Bike: Triumph
johnyC's Avatar
I just did my valves recently, had to change one of the exhaust shims. The shims are 25mm and are easily had. Two of my local bike shops, one a Honda dealer, had a big assorted box of them. The one I got was £3.
johny. the boy's happy, leave him alone.
johnyC is offline   Reply With Quote
CR Carb Question Trumpedup Twins Technical Talk 1 02-17-2008 08:27 AM
carb question retrobiker Classic, Vintage & Veteran 7 11-02-2007 03:48 PM
Question about carb jermoto Twins Technical Talk 2 02-04-2007 11:12 PM
Newbie carb question 2002 Bonneville stu Twins Technical Talk 10 07-13-2006 06:17 PM
Another carb question dave31grant Twins Talk 2 01-23-2006 07:58 AM
