Trident fork oil levels - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-10-2005, 06:00 AM   #1 (permalink)
Does anyone know how much oil to put into my 1993 Trident 750. Manual uses a tool to draw out excess oil to a set distance from top face of leg. Leg completely compressed. I dont have access to this tool so can anyone tell me a capacity. :???:
Wavey is offline   Reply With Quote
Old 10-10-2005, 07:20 AM   #2 (permalink)
Trident 750 , VIN 4902 to 44301, SAE 10, 109 mm ( max 97 mm)
Any graduate rules will be ok to perform the job
You don't need a specific Tiumph tool just to make a mesurement
legend21 is offline   Reply With Quote
Old 10-10-2005, 08:37 AM   #3 (permalink)
Favourite Bike: 1995 Thunderbird
SWare's Avatar
I use a small steel ruler with a piece of cardboard taped across to make a T at the appropriate place, i.e., 109mm. Then just use it as a dipstick.
Stan
SWare is offline   Reply With Quote
Old 10-11-2005, 06:59 PM   #4 (permalink)
I used a three foot length of clear plastic tube, the stuff you get at the D.I.Y store, taped it to the rule, filled the fork to approximately the level and sucked out the excess, using my lungs, then blow the oil back into the bottle.
Don't suck too hard the stuff tastes rank.
Joules..
Bodger is offline   Reply With Quote
oil and brake fluid levels bricktop Twins Technical Talk 1 04-06-2007 08:26 AM
British Press and Oil Levels PIKACHU0003 The Rocket Science Forum 9 09-26-2006 09:38 PM
fork oil levels psds Classic, Vintage & Veteran 4 06-24-2005 02:33 PM
Oil levels on a '69 twin ??? Maintenance & Workshop Talk 1 10-12-2004 08:36 PM
900 EFI Oil Levels knarf Tiger Chat 5 07-02-2004 05:25 AM
