08-10-2011, 06:39 AM
Grand Prix 250 Main Motorcycle: TBS 2004
Sidestand length
I tried to rise the forks my tbs to see how it handles, in case I decide to go for clipons. However, rising the forks made the bike very unsteady on the sidestand. So I understand the T-bird stand is shorter than the TBS sidestand? I measured my stand to be 27 cm (10"5/8) from center of the bolt to the ground. Could someone please inform me how long the sidestand is for a the T-bird. What other options do I have, legend...?
08-10-2011, 01:33 PM
SuperBike Main Motorcycle: my 1999 triumph legend
I put a T bird stand on my Legend after changing the rear shock. Legend stand is shorter than T bird, but I don't know how either compares to TBS?
08-10-2011, 03:26 PM
Site Supporter Team Owner Main Motorcycle: 98 Thunderbird
Posts: 4,552 Other Motorcycle: 03 Speedmaster
The Tbird stand should be longer than the legend and shorter than the TBS. If no one answers in the meantime, I will measure mine tomorrow.
08-10-2011, 03:41 PM
Will someone with each kind of bike list the lengths.
2000 TBS Cafe Racer :: 2000 Frankenmille
08-10-2011, 04:25 PM
Thank you that would be great!
God idea. Then we'll know for sure.
08-10-2011, 08:55 PM
Site Supporter Moto Grand Prix Main Motorcycle: '98 Thunderbird Sport
Posts: 3,193 Other Motorcycle: '06 Husqvarna TE 610 Extra Motorcycle: '95 TBird - Project
OK, OK
Took some pics.
In summary. The TBS and TBird stand measure the same 240mm length, but the TBS stand is straight where the TBird stand is bent.
The Legend stand is only 220mm long and is bent similar to the TBird stand.
Also a friend here in Indy area has a 2004 TBS and his sidestand is slightly longer than the stand on my 98 TBS.
Cheers,Denny
08-11-2011, 04:34 AM
Originally Posted by denny
OK, OK
Took some pics.
Tank you Denny. That makes good sense. I always thought my TBS is standing more upright than older ones. I guess Triumph changed the length for the 2004 model (or perhaps earlier). I guess the issue of the bent and straight differences between T-bird and older TBS is due to the exhaust.
In conclusion I will first go for the T-bird stand.
08-11-2011, 03:00 PM
As Denny says, I made it 240mm from bolt centre to the bottom
08-11-2011, 04:04 PM
Powerbike Main Motorcycle: '04 Thunderbird
Posts: 344 Other Motorcycle: 1998 Honda CBR1100XX
When I added cast wheels, TBS forks and TBS rear suspension to my Tbird, I had to lengthen the TBird side-stand accordingly as the bike was then too tall for the original side-stand.
I had intended to weld some flat bar to the 'foot' of the stand, but I ended up just bolting on a small piece of hardwood - about 15mm thick from memory. I only planned to do this as a temporary measure, since it was an easy way to establish the correct thickness of steel to weld on, but it worked well enough to just leave in place.
BTW: Don't make the side-stand too long, as if you get a flat rear tyre, the bike may not be able to lean over far enough to rest on the stand.
08-11-2011, 08:37 PM
Supersport 600 Main Motorcycle: 1996 Tbird
Posts: 175 Extra Motorcycle: 2000 Sprint ST
That is very good advice as I probably would have done that.
Travis
Triumph is not for everyone. The most common side effects of Triumph are headache and upset stomach. Stop taking Triumph and contact your doctor immediately if you have difficulty breathing. Ask your doctor if Triumph is right for you.
