lOSS OF POWER. - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsSportbikeTrackGearNew Bonneville
Old 10-06-2005, 02:45 AM   #1 (permalink)
kilda
Went for a 4 day ride last week on the legend. My first big run. All was well except on 3 occasions over the 1300klm run the bike faded on me - losing all power. When I pulled over and restarted away she went. Anyone been there and done that?
Cheers Kilda
Old 10-06-2005, 04:04 AM   #2 (permalink)
Yeah mate it sounds like the old tip over valve thingie. Try opening the fuel cap when it does it, if you hear a hissing thats it.
Also could be a blocked or partially blocked fuel tap filter. Or the little duckbill filter in the fuel line where it tees to the carbies. Mines got a little sintered bronze filter there, but some others have said theres a plastic duckbill filter.
Hope this helps
JWoodsie is offline   Reply With Quote
Old 10-06-2005, 10:12 AM   #3 (permalink)
Favourite Bike: '98 Triumph Sprint Ex.
Extra Motorcycle: '02 Kaw Ninja 250
And if it's not what JWoodsie mentions it's probably the pick-up sensor. Also known as the crank position sensor. Common problem, inexpensive and easy to change out.
j98sprint
j98sprint is offline   Reply With Quote
Old 10-06-2005, 11:09 AM   #4 (permalink)
kilda
Couldn't give me a bit more on what/where is the pick up sensor j98sprint?
I'm very much the bignner.
Cheers Kilda
Old 10-07-2005, 05:16 PM   #5 (permalink)
Favourite Bike: 1995 Thunderbird
SWare's Avatar
I thought of mentioning the pick up sensor as well.
I haven't had a problem with mine but from what i've read the bike would have to cool a bit before it would run again. Your description makes it sound like it will start moments after it dies. That would make me think the tip over valve or gas cap vent.
The pick up sensor is under the right hand crank cover.
Two screws and unplug is about it. There is an air gap to check during re installation.
Here is a picture that shows the sensor pretty well.
Stan
[ This message was edited by: SWare on 2005-10-07 19:10 ]
SWare is offline   Reply With Quote
Power Loss wozman Twins Talk 3 11-12-2005 03:24 PM
loss of power(wheelies) Agkistrodon Speed Triple Forum 6 09-16-2005 03:11 PM
Trident power loss T3 Sport / Touring Forum 6 02-14-2005 06:08 AM
Trident power loss Hinckley Classic Triples 2 02-13-2005 07:22 PM
Trident power loss Maintenance & Workshop Talk 8 02-13-2005 07:19 PM
