10-05-2005, 10:45 AM
Formula Extreme Favourite Bike: 96 Bird
Posts: 492 Other Motorcycle: 97 BMW R850R Extra Motorcycle: 71 Bonnie
anybody using that radiator flush stuff in there bikes?? u know ...the cleaner...any feedback ....good bad .. ?? ....tom
its not leaking oil!!...its marking its spot!!!
10-05-2005, 03:08 PM
Grand Prix 250 Favourite Bike: Thunderbird 900 1997
Posts: 68 Other Motorcycle: Bonneville Special T140D
Tom,
The Haynes manual states that the flush should be suitable for aluminium engine parts.
I would like to flush the system as well but I will have to get replacement seal/washers on the two drain bolts as my '97 Tbird does not have the lower rubber pipe coming out of the bottom of the pump - as recommended in the manual!
The parts fiche is not very clear in showing these two seal/washers, and am concerned that the parts dept chap will get the wrong ones.
John
10-05-2005, 04:04 PM
Site Supporter Pole Position Favourite Bike: 98 Thunderbird
Posts: 4,098 Other Motorcycle: 03 Speedmaster
I have drained mine 2 or 3 times, never had to replace the washers.
As for the rad flush, I would not bother unless there had been some sort of problem like a leaking head gasket. You could always reverse flush it with a hose pipe, that should be sufficient.
10-05-2005, 08:56 PM
If the system isn't contaminated it doesn't need to be flushed. Flushing a system excluding brakes flushes only one thing. Your wallet. I'm a service manager at a Honda auto dealer and we do not flush anything. It is a big profit builder, but is just ripping off the customer. We chose not to do it.
JR
10-06-2005, 09:36 AM
guttermonkey... u mean u dont bother to replace antifreeze at all..or dont bother with the cleaner ?? ...tom
10-06-2005, 10:06 AM
Site Supporter Pole Position Favourite Bike: Well, Duh!
Posts: 3,650 Other Motorcycle: Can't afford two! Extra Motorcycle: Three would be insane
I concur and would recommend a reverse flush - it will remove quite a bit of sludge.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
10-06-2005, 01:45 PM
OK,
Silly question
For reverse flushing where do you stick your hose?
Thanks,
John
10-06-2005, 06:37 PM
yes....how bout a little more detail on the reverse flush procedure ......tom
10-06-2005, 07:05 PM
World SuperBike Favourite Bike: 1958 Norton Nomad
Posts: 2,009 Other Motorcycle: 2000 Triumph TBS
I flushed my coolant system this spring. All I did was remove the drain plug (somewhere by the horn) and let the old dirty crud drain out. Then I put the garden hose in the opening for the rad cap and flushed away.
Works great and is free.
No gaskets or washers need replacing.
" If you haven't been paying attention to what's going on in the world around you perhaps you should start. It certainly beats relying on erroneous rhetoric to form one's opinions." Steven Lloyd
10-08-2005, 07:37 PM
I should have been a little more clear in my first posting. A drain & refill should be all you need. If you have sludge build up it is the result of not changing the coolant often enough, coolant contamination or just a poor grade of coolant. The coolant we are using now in the cars is good for 120K miles. JR
