well it only happens once in a while when cruising steady and going over bumps and cracks in the road but not under acceleration or decelleration .
it sounds like quickly brushing a japanese motorcycle horn like eep not beep and twice as loud as one (same pitch at any speed above 40 mph and only happens above 40
ive checked the alternator and its not the culprit
oiled the speedo cable
tapped wiggled and checked everything i could think of even removed both sidecovers on engine. nothing loose no shavings no glitter in oil,,,,nothing,,, unhooked the horn and problem still persists
. I cant duplicate it unless im moving so im totally at a loss here
so im down to ,,,the bike has to be moving and only rough roads set it off
can there be something involved in cam chain/ tensioner or valve train that would make this sound?
i wouldnt think something internal could be so dang loud but im new to all this and im not giving up my t-bird for anything
ive wanted one every since i was in high school 27 years ago and now i finally got one
[ This message was edited by: darcon on 2005-10-05 09:38 ]
