Specifically the issue is the centrifugal oiler in the left, front engine case. Originally these were mostly plastic and eventually with all its spinning it would deform, hence the leak. The replacement one is black and the center is metal. Three parts will need to be ordered, engine gasket, oiler and seal; should be less than $100 in parts.
2000 TBS Cafe Racer :: 2000 Frankenmille
