Legend TT problem - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-31-2011, 07:41 PM   #1 (permalink)
Legend TT problem
Hey people! Just had a couple of questions for you.
I just got my 2001 Legend TT and I'm just getting to know the bike.
One of my concerns is that I feel like it's running a bit rich and the engine starts to break up in the lower gears...almost like it's coughing a little bit. when i open it up fully i dont get this this just happens in the lower gears.
Any idea what this could be and can i fix it without having to disassemble the carbs?
Thanks guys!
Carl Sagan is offline   Reply With Quote
Old 03-31-2011, 08:18 PM   #2 (permalink)
Main Motorcycle: '99 Legend / '98 TBS
BigAl8295's Avatar
If it's a little rich, you can adjust the air/fuel mix screws.
Is everything stock on the bike?
FCR-39 Carbs, Sprint Cams, British Customs Predator Exhaust, K&N Pod Filters, Nology Coils, Ignitech Ignitor, Progressive Fork Springs, ZX-6R shock, and one bad ass Horn Cover!
Charm City Mods vs Rockers Rally
BigAl8295 is offline   Reply With Quote
Old 04-03-2011, 12:47 AM   #3 (permalink)
Main Motorcycle: 1953 Triumph Black bird
Kem770's Avatar
Other Motorcycle: 1978 Yamaha DT400
This can be caused by old fuel, so are you on your first tank?
Kem
A man cannot be comfortable without his own approval.
Mark Twain
Kem770 is online now   Reply With Quote
Old 04-04-2011, 10:35 PM   #4 (permalink)
It's new fuel. I took the bike to the shop so we'll see what the experts say!
Old 04-07-2011, 04:55 AM   #5 (permalink)
Main Motorcycle: Triumph Legend
Experts...
I can't wait...for some reason these bikes seem to psych experts out
On a serious note, there are some important peculiarities that can cause problems such as rusting fuel tank, the duckbill filter, ignition coil etc. that can be perplexing without prior knowledge.
Good luck!
buxtonmick is offline   Reply With Quote
Old 06-02-2011, 11:42 PM   #6 (permalink)
Jonesy's Avatar
How did you go? Any luck? I've been having similar issues with my '99 Legend TT. I'd be interested to hear any news!
Jonesy is offline   Reply With Quote
Old 06-03-2011, 08:16 AM   #7 (permalink)
well, the jetting was all out of whack because the person who owned it before me got aftermarket mufflers put on but did not rejet. Also, there was a bug in my third cylinder (like an actual bug). Once those two things were taken care of it was all set.
Old 06-03-2011, 08:57 AM   #8 (permalink)
Jonesy's Avatar
Interesting. I'll have to get it checked out when I've got some time off. Cheers!
Old 06-03-2011, 05:09 PM   #9 (permalink)
Main Motorcycle: 2001 Legend
Blueskys105's Avatar
I think every Triple owner goes through these same issues. I started with all the cleaning business till I finally broke down and replaced the coils. It always (or mostly) seems to come down to that. The tricky part is when the dealer puts in new plugs and it works great for about 200 miles, then the problem shows up again.
Make sure everything is clean, floats are set to the correct height - put in iridium plugs (that's a lesson in itself) then replace coils with Nology. I bought wires too but I think that was a waste of money, hard to tell. And.... stay out of downtown Orlando. Worst drivers on the planet live there.
Blueskys105 is offline   Reply With Quote
Old 06-03-2011, 11:32 PM   #10 (permalink)
Jonesy's Avatar
It's probably due to have those kind of bits and pieces replaced anyway, being 12 years old with 56k km on the clock. I'll check that out too, thanks!
And I'll bear that in mind about Orlando but not much chance of finding me there in the near future. I'm in Australia
Triumph Legend Problem need help. sydt160 Hinckley Classic Triples 3 10-25-2010 09:57 AM
Legend TT Idle Problem nsinsabaugh Maintenance & Workshop Talk 11 09-16-2009 06:11 AM
Legend TT Idle Problem nsinsabaugh Hinckley Classic Triples 3 09-15-2009 08:33 AM
problem with legend speedo bobsyeruncle Hinckley Classic Triples 1 09-06-2009 06:51 AM
Legend problem. Help Help! Terryd Hinckley Classic Triples 4 04-07-2009 11:03 AM
