Old 09-06-2005   #1 (permalink)
Hi Folks - This is my 1st posted message - hope someone can help. I wish to raise the existing handlebars on my 2001 Legend up and back toward me so I don't need to lean forward quite as much. I prefer to be able to reuse the Triumph top clamp if possible. Can anybody suggest a good source for this?
Legendman is offline   Reply With Quote
Old 09-06-2005   #2 (permalink)
GenMar makes a set of risers that will move your bars up 1 inch and back 1 3/8 inch. They are expensive at $110 US .
You can see them at http://www.zianet.com/GenMar
Rodan
Rodan is offline   Reply With Quote
Old 09-06-2005   #3 (permalink)
I use the standard Gen-Mar risers. I think they were $85 US. They are vertical, but the rake of the fork makes the bars go back as well as up.
The standard cables work with this rig; the one that goes up and back might require longer cables.
My Photo Album
triumphantguy is offline   Reply With Quote
Old 09-06-2005   #4 (permalink)
What about using Thunderbird bars, I think they have more rise and pullback.
2000 TBS Cafe Racer :: 2000 Frankenmille
TBSstunta is offline   Reply With Quote
Old 09-06-2005   #5 (permalink)
I put SW Motech 30mm risers on mine. Top clamp works fine, however, the two sets of bolts they give you are both too long. I now have 5 washers on each one and the handlebars still rotate a bit under stress. I'm going to have to find a source for stainless steel hex-head bolts in the correct size.
See the pictures/description here:
Handlebar risers on
If all you want is more pullback, you can get a new set of handlebars for half the cost of the Motech risers, $20 vs. $40 for the risers.
Martin
"They were long and low and sleek and fast, they were classic, in a word/Back in '55 we were Makin' Thunderbirds" - Bob Seger
UJMrider is offline   Reply With Quote
Handlebar Risers BillyRaff Twins Talk 6 05-20-2006 10:35 PM
handlebar risers hal26 Speed Triple Forum 1 05-06-2006 12:27 PM
Handlebar risers robbierob The Rocket Science Forum 2 01-01-2006 12:41 AM
Handlebar risers, 05 ST b50bsa Sprint Forum 7 07-02-2005 07:21 PM
Handlebar risers smartin108 Tiger Chat 1 03-03-2005 09:51 PM
