Mixture screw location? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Motorcycle.com Classifieds!Motorcycle.comSportbikeTrackGear
Old 08-17-2005, 04:54 PM   #1 (permalink)
JonnyAstro
Hi,
I read in the download tuning guide about reducing over-run "popping" by adjusting the carb mixture screws to "1 -1/2 turns". I have a '95 Thunderbird with Mikunis - which ones are the mixture screws?
Old 08-17-2005, 06:55 PM   #2 (permalink)
From Factory Pro's Site
Click for rest...
Pics
Ted: There's a G in 'Dougal'. Dougal: Where?
maxpower is offline   Reply With Quote
Old 08-18-2005, 05:40 AM   #3 (permalink)
You'll find that it's a real pain to get to these without dismounting the carbs. I finally got my self an angled gear driver to get to the middle one. It's possible to reach if you've got small hands, though.
Oh, and I don't know about the Mikuni's, but on the Keihins I found that I had to turn the screws almost three turns out. Downside is a bit rough at take-offs, but idling is better, and pop/fart reduced considerably. It won't disappear totally.
Oh, and I have drilled out my stock silencers. Quite a bit more than the usual drill procedure I might add.
T'Weed
The future's so bright, I gotta wear shades
Tumbleweed is offline   Reply With Quote
Idle mixture screw Blacklion50 Maintenance & Workshop Talk 1 04-11-2007 11:02 AM
Mixture screw adjustment swgee Maintenance & Workshop Talk 3 01-03-2007 12:15 PM
What does the mixture screw do? n578md Twins Technical Talk 7 08-12-2006 09:27 PM
Mixture Screw dave31grant Twins Talk 5 01-11-2006 10:37 PM
Idle mixture screw, in or out Lovechops Twins Talk 5 10-10-2005 01:27 PM
