The Haynes manual lists the pick-up coil resistance at 530 ohms (+ or - 10%), so maximum value for a working coil would be 583 ohms.
Picked up a replacement coil and took it to a friend (electrical technician - tv studio)to check the resistance with his analog multimeter, and he got the correct values. I then tested it with my digital multimeter, and got the same reading, so presumably both instruments were in synch. Went home, put my meter on the pick-up coil, and got a reading in the 700's. At the risk of asking what may be an obvious question, a reading this much higher than 583 would indicate a bad coil, correct? Thank you in advance.
Find a resistor with a known value of approx. 600 ohms, test it with your meter.
This will tell you what's going on with the meter.
Put a fresh battery in your meter.
They can get funky if the batt's low.
IrlMike, the reading was over 700, so looks like a replacement will be next.
Jimbo, the replacement part was off the bike. I tested the original on the bike, both cold and hot (used a hair dryer on high for 7 minutes), and got the same readings each time.
Gotcha.Just trying to get this sorted out with ya.
I still think it's worth rechecking the "replacement" with a known accurate meter.
Of course if this is a used replacement, the reason it's "used" may be obvious.
Just tryin' to save ya a few bucks.
Many thanks for your input. I greatly appreciate ANY suggestions to save some $'s!
As far as checking the replacement P-U coil with a known accurate meter, I have a lot of confidence in my buddy's analog. As a TV tech, his stuff has to be up to speed. That's why I took my multimeter over to him to compare the readings.
Looks like I'll be removing the old P-U coil, and replacing with the one we both tested.
Thanks again for your interest and suggestions. It's guys like you that make this forum such an incredible resource.
Related Threads
Triumph Rat Motorcycle Forums
3.9M posts
167.7K members
Since 2002
