Sticky Carbs Anyone? - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 08-12-2005, 07:55 PM   #1 (permalink)
Sorry no Glazed Donuts here.
For past two days, after the bike has been ridden for more than 10 minutes(well warmed up) and during Clutch in throttle back/off shifting at 4000 RPM, I have been noticing that the engine is briefly gaining RPMs, holding them instead of immediately tapering off. If I shift 3K or 5K RPM the problem does not manifest itself. Currently it's just an annoyance but I am concerned It may get worse.
Throttle linkage appears to operate smoothly with out binding. It been Hot 95f and humid ~60% not sure if this affects things. There is less than 15K miles on the clock and the bike is stock. Otherwise it is running fine.
I was thinking perhaps one of the slides was getting a sticky spot at 4K RPM, where I like to cruise or perhaps a dirty air filter letting her run rich.
Pics
Ted: There's a G in 'Dougal'. Dougal: Where?
maxpower is offline   Reply With Quote
Old 08-13-2005, 12:56 AM   #2 (permalink)
jimmyj900's Avatar
Check the air filter and also check the carb outlet rubbers and vacuum takeoff covers for cracking.
Beyond that, the Mikuni carbs are subject to both slide wear and needle/needle jet wear, so if it's not an airflow problem it's time to open the carbs and take a look.
Jim
Sticky RonD Twins Talk 16 12-22-2007 11:12 PM
Sticky brake... Percanto T3 Sport / Touring Forum 5 12-23-2006 03:21 PM
Trophy CV carbs at varying altitudes.... EFI vs CV Carbs TiggerTwo Trophy 9 01-17-2006 02:07 AM
sticky throttle? Treehugger Triumph SuperSports 2 04-09-2005 06:55 AM
Sticky Throtle???? TURBOTECH Daytona Deliberations 1 11-18-2004 01:00 AM
