Bad Plug Wire - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-10-2005, 01:54 PM   #1 (permalink)
jimmyj900's Avatar
My bike developed a misfire on one cylinder and since I had the valve cover off I figured I might have oil in a plug cup.
When I pulled the number 1 plug wire there was no "click" of connector coming off the top of the plug, so I tried to reseat it. Again no click, so I removed the plug wire for a closer look and poked a spare plug in and out a couple of times to verify and still no click.
I figured I was screwed for a $100 set of plug wires either way, so I decided cut off bottom end of the rubber boot and broke off the plastic shell of the underneath until I could get to the metal connector.
The connector itself is a metal tube with a slot sawn in it and a piece of spring wire in the slot to make contact with the threads on the top of the sparkplug.
What I found was that the spring wire was so badly eroded from arcing that it broke when I removed it.
After trying several wire types to replace the broken bit, I found that 20ga. galvanized soft-temper steel picture hanging wire worked perfectly.
The net result is that the bike is running quite happily and I can hold off buying new wires until later in the year. :-D
Jim
Scrambler plug gap and nology wire grounds Bulldog51 Maintenance & Workshop Talk 1 05-22-2007 01:19 AM
Plug Wire Replacement?? tigerwilson Tiger Mods & Bolt-Ons (archive) 2 11-07-2006 02:37 PM
wire wheels Joe275 Hinckley Classic Triples 3 04-04-2006 11:06 AM
bad bad crankle / question on engine swapping Regiz Hinckley Classic Triples 3 12-12-2005 12:30 PM
Spark plug wire resistance j98sprint Maintenance & Workshop Talk 5 03-30-2003 03:10 AM
