Mufflet mounting snag - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismHonda PowersportsSportbikeTrackGearMotorcycle.com
Old 08-09-2005, 06:23 PM   #1 (permalink)
Favourite Bike: 2001 BMW R1100RT
Tommybro's Avatar
Extra Motorcycle: Triumph T100 Bonneville
I bought a pair of used stock peashooter silencers on Ebay that came off A '95 Tbird. Unfortunatly one of them is missing the threaded anchor bungs that mounts to the bracket.
I thought of some kind of a lead shield insert that would expand when the mounting bolt is inserted. Couldn't find anything close the the size needed at the local Home Depot. If I did would it get soft and come out with the heat? Didn't see any kind of anchor bolt that would work. Welding a nut on the outside?
Anyone run in to this? I posted on the Workshops section with no responses.
T.
1997 Triumph Sprint 900
2003 Honda 919 CB900F
Tommybro is offline   Reply With Quote
Old 08-09-2005, 06:25 PM   #2 (permalink)
Favourite Bike: Hinckley Classics
vonbonds's Avatar
I think they are called RivNuts. Not sure how you repair that though. Maybe some of the more experienced wrenches on this site can help you out.
Tom
vonbonds is offline   Reply With Quote
Old 08-09-2005, 10:58 PM   #3 (permalink)
Good Idea vonbonds:
Makes me think of trying Pop Rivets Pop rivets they come in a variety of sizes and metals. Cheap and Easy to use. Also can be easily removed if necessary.
Pics
Ted: There's a G in 'Dougal'. Dougal: Where?
maxpower is offline   Reply With Quote
Old 08-10-2005, 01:34 AM   #4 (permalink)
ClassiclyMobile's Avatar
You should return the exhaust to the seller for a full refund and post negative feedback if he doesn't cooperate. You got ripped off.
ClassiclyMobile is offline   Reply With Quote
Mounting windscreen??? T-bone Speed Triple Forum 5 05-19-2007 05:01 AM
Tire Mounting S_Mues Speed Triple Forum 8 04-22-2007 01:13 PM
HELP!question about installing ard magneto? hit a little snag! dgfironworks Classic, Vintage & Veteran 2 12-26-2006 08:11 PM
Charging snag - 04 Sprint jonny Sprint Forum 4 10-02-2006 01:48 PM
New Spirint Snag List Goes On And On! PIP1980 Sprint Forum 24 09-21-2005 04:19 AM
