Just a quick question about tightening the chain (seeing as how I haven't owned a chain-driven bike since 1985):
I noticed there are two nuts on the screw that presses against the axle. I assume the top nut (i.e. farthest from the axle) is just there to keep the other one from backing out?
I have a manual, but it must be from a 1995 or 96 b/c is shows the adjustment being done with some eccentric screws on the axle itself.
I assume the procedure is as follows:
Bike on the center stand, so rear wheel can turn freely
Loosen the "top" nut on either side of the axle so bottom nut can turn freely
carefully tighten "bottom" nut, turning one side and then the other, until the chain has 30mm of slack at a point between the rear sprocket and the tranny case (incidentally, the manual says 30mm of slack, but also says it's measured when the bike is on the side stand, which means the wheel is on the ground. Is it still 30mm if the bike is on the C-stand and the wheel is hanging free?)
Then tighten the "top" nut down onto the "bottom" nut.
Does that sound right? Also, how do I make sure the axle is perfectly perpendicular to the direction of travel?
Martin
08 Scrambler "Unscrambled": AI removed, Dunlop D404 street tires fitted, Bonnie Saddle, Slipstreamer S60 windscreen, Renntec Rack, JC Whitney top box and handgrips, Triumph C-Stand and number board kit, 1" handlebar spacers.
