I was out and about tonight on my bird. Now typically I ride with my high beams on, for safety/visibility, but most of my riding is during the day.
Well, tonight I turned off my high beams, then turned off my driving lights, and the road got really dark. I knew the low-beam was poor, but it was ridiculous. So I took a look at it then, and saw it was just my parking light that's lit when the switch is on low-beam (the dim light that comes on if you turn your key past the steering lock setting).
I changed my headlamp to a xenon version of the same wattage many months ago, btw. I have a spare lamp, and the old one, which I may try swapping out later. But it seemed to me that this might be a problem with the switch rather than the lamp, as the high beam works just fine.
Any ideas?
Thanks.
