Old 07-27-2005   #1 (permalink)
Administrator
Favorite Bike: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
I have seen in many post on here re modding of carbs that I need to put a copper washer under the needle in the carb,
My confusion is based on:
Does this washer have a part #?
Is it particulat to Keihin carbs?
What are its dimensions?
Might I happen to have one in my tool box?
There are many other questions leading to my overall confusion, but these are related to upgrading my carbs.
Any and all help will be appreciated.
Bob
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is online now   Reply With Quote
Old 07-28-2005   #2 (permalink)
Favorite Bike: 98 Thunderbird
No, no part #. It is purely an unofficial mod.
The mod is relevant to any bikes with non-adjustable needles, or even some that do adjust, for fine tuning.
Dimensions, going from memory, the washers I used were 3mm ID (about 1/8").
You would need at least 3, possibly 6 depending on how thick they are and how much you want to raise the needles.
Old 07-28-2005   #3 (permalink)
Favorite Bike: Scrambler
johnyC's Avatar
Wombat,
the copper washers I used came from a pack of 'assorted copper washers' bought from a Halfords auto parts store. The thickness of one (all I used) would be similar to one notch worth on an adjustable needle, it richened up the mid range enough to compensate for the K&N and extra holes in the airbox.
johny. the boy's happy, leave him alone.
johnyC is offline   Reply With Quote
Old 07-28-2005   #4 (permalink)
Administrator
Wombat's Avatar
Thanks Johny,
I have decided to follow your lead on the airbox mods and jetting.
I have no clue as to the spacing on the adjustable needles or even if the needles in my carbs are adjustable.
About how thick would the washer be that i may need to use?
Bob
[ This message was edited by: Wombat on 2005-07-28 02:36 ]
Bob
Old 07-28-2005   #5 (permalink)
In my experience the needles on Keihin CVK carbs are not adjustable but the needles on Mikuni carbs have 3 needle slots. Early models have Mikuni's late models Keihin's.
I rejetted due to fitting pod filters but did not see the need to put copper washers under the Keihin needles. All I set out to do was to increase the fuel flow rate to match the increased air flow rate provided by S&B maxi flow filters which have a lower pneumatic resistance than the restrictive standard airbox.
BigVinny is offline   Reply With Quote
Old 07-28-2005   #6 (permalink)
johnyC's Avatar
Wombat,
the washers I used are about 1.5mm thick, equivelant to moving a notch or two on an adjustable needle, but a bit less scientific. The TBS (Keihin) needle you have is not adjustable, you put the washer beneath the needle (to raise it, making that stage richer) and put it back into the slide to get the same effect.
Carb Mod Questions haggis95 Twins Talk 1 07-25-2007 01:24 PM
Single Carb mod, 650 Bonneville Northern650Twin Classic, Vintage & Veteran 22 07-26-2006 10:27 PM
amal carb pilot-circuit mod kanoa Classic, Vintage & Veteran 2 03-31-2006 08:24 AM
cv carb vacuum slide mod Gohm Modifications & Workshop Talk 1 06-21-2005 10:29 AM
CV carb mod Gohm Club Cafe 9 06-12-2005 12:29 AM
