Old 07-26-2005   #1 (permalink)
Today I fitted the Daytona wheel on the TBS. The fit was quite easy. The main difference between the 2 wheels is the length between the forks. The Daytona wheel measure 152 mm from the outside of the speedo drive to the outside of the spacer while the TBS wheel is at 145 mm. Since all older Triumph are using the same speedo drive, that side is equal on all wheels. The difference is on the other side. All I had to do was take out 7 mm from the spacer on the other side of the wheel. Perfect fit with the calipers, no problems.
I did have the axle of the Daytona wheel but that is useless since it is too long. I also had the spacer so I can use both sets of wheels.
I did try to post pictures but I am having problems logging on to my server. As soon as I can I will put a few pictures.
In doubt, crank the throttle.
Saigon5 is offline   Reply With Quote
Old 07-26-2005   #2 (permalink)
How about the rear wheel have you still got the spoked wheel on,hope to see the pics soon
Ben
.. :hammer:
:yayyy:
benthepaint
I am not old not young just persistent
benthepaint is offline   Reply With Quote
Old 07-26-2005   #3 (permalink)
I have the back wheel also. That is an easy straight fit except for the brake rotor. I did order one from Sprint Manufacturing, again in order for me to use both set of wheels.
[ This message was edited by: Saigon5 on 2005-07-26 18:58 ]
TBS rear wheel upgrade Johnjohn Hinckley Classic Triples 8 11-06-2006 04:24 PM
Wanted TBS Aluminum Rear Wheel gregzilla Hinckley Classic Triples 0 01-16-2006 09:36 AM
Thunderbird/TBS front wheel swap ? Slinky Hinckley Classic Triples 27 10-20-2005 05:39 AM
Daytona wheel on TBS with pictures Saigon5 Hinckley Classic Triples 4 07-29-2005 10:12 PM
Removing & Replacing rear wheel on Y2K-TBS Modifications & Workshop Talk 29 07-29-2003 06:38 PM
