Trident-Exhausts.comSoupy's PerformanceTriumphPerformanceUSAMotorcycle.comSportbikeTrackGear
Old 07-19-2005   #1 (permalink)
I was not going to play with the carbs again this year but since I had a problem of air draft with the TBS air box with holes I decided to put back the Trophy box with a K&N filter. I changed the jetting to 142-138-142 and I did put 1/2 shim under the needles. With this set up I am now a little poor on top which will bring me to put the main jets at 146-142-146 and I will remove the shims in order to help the rich curve I have in the middle.
Up to now I can not get rid of that rich part between at5500 (on the chart may not be in life) The fuel air ratio is 10 to 1 for a short period of time. Further in the range with the 142 main I am now too lean at 14 to 1
I still get about the same HP at 87.4 instead of 87.7. That should reach 88 with the 146 jets. To my surprise I get 2 (ft-lbs) of torque more now sitting at 59.4
To get a more even fuel air ratio I may have to fiddle with something I am not familiar with. The different options are to fiddle around the level of gas in the carburator bowl, play with the neddle springs or with the slide opening.
I will give up there this year for the carburator and will work on my wheels.
In doubt, crank the throttle.
Saigon5 is offline   Reply With Quote
TBS, cams, dyno run, Comparo Saigon5 Hinckley Classic Triples 0 05-07-2005 04:22 PM
TBS, cams, dyno run, part 4, the latest Saigon5 Hinckley Classic Triples 4 05-05-2005 11:16 PM
TBS, cams, dyno run, part 3 Saigon5 Hinckley Classic Triples 9 04-28-2005 09:23 PM
TBS, cams, dyno run, part 2 and 1/2 Saigon5 Hinckley Classic Triples 4 04-21-2005 10:40 PM
TBS, cams, dyno run, part 2 Saigon5 Hinckley Classic Triples 8 04-17-2005 10:43 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
