Grease - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-13-2009, 01:41 PM   #1 (permalink)
Favourite Bike: '03 Thunderbird
Grease
What kind of grease do you recommend for the brake and clutch levers (handle bar)?
I am replacing the levers and shoulder bolts.... Should it be moly grease, or lithium?
Lithium is more stable at high temps (think sunlight on black metal), but has a tendency to attract/absorb moisture. Molybdeum grease doesn't have the water problem, but has a lower melting (liquefying and oozing) point.
Looking forward to your input.
Darien
Darien is offline   Reply With Quote
Old 11-13-2009, 03:18 PM   #2 (permalink)
Favourite Bike: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '06 Husqvarna TE 610
Extra Motorcycle: '95 TBird - Project
I use Lithium grease for those kind of things...
Donning my Flameproof suit.
Cheers,Denny
denny is offline   Reply With Quote
Old 11-13-2009, 03:35 PM   #3 (permalink)
Favourite Bike: my 1999 triumph legend
ssevy's Avatar
I use the same Dupont Multilube teflon spray that I use on my chain. The vehicle evaporates off, leaving the teflon coating in place. For the cables themselves, I use Bike Aid, which is a liquid graphite slurry, which, again, evaporates leaving the graphite in place. The biggest problem with grease and other heavy lubricants is that they attract and hold dirt, which then acts as an abrasive on the moving part. (I think most chain wear is probably due more to the typical heavier chain lubes attracting and holding dirt in the chain links, which then gradually grinds away all of the friction points as you ride, rather than a dry chain.) On my Farmall Cub tractor, I apply grease to all of the fittings until it squeezes out of the joint, which forms a seal keeping the dirt on the outside of the part. In this situation, the heavier grease is fine, because the application through the grease fittings pushes the fresh grease toward the outside, and generally forces out any dirt or contaminants which could have migrated into the joint.
ssevy is online now   Reply With Quote
Old 11-13-2009, 04:32 PM   #4 (permalink)
Slinky's Avatar
White chain wax, at least when I remember.. on the cables I run a few drops of thin oil down and then seal the end with a little squirt of chain wax.
Old 11-15-2009, 02:54 AM   #5 (permalink)
Favourite Bike: 1999 legend
buckoz's Avatar
i use wd40 on that and cables grease in exposed areas will collect dust
marine grease for wheel bearings and steering head
sun comes up sun goes down when that stops then we worry
buckoz is offline   Reply With Quote
What was the Motorcycle In Grease 2? deezildennis Biker Hang-Out 7 01-04-2009 11:42 PM
Out of date grease?? Tone in't Fens Tiger Workshop (archive) 9 07-27-2008 08:07 PM
Grease?? John21 Sprint Forum 30 12-21-2007 01:49 AM
what is that grease? junabug Club Cafe' 5 05-26-2006 02:51 AM
Best Grease zighawk Twins Talk 0 10-10-2005 03:00 PM
