TriumphPerformanceUSAMotorcycle.comEPG MotoRicor ShocksTriumph DetroitSoupy's PerformanceOPP RacingCommonwealth Motorcycles
Penn Foster
Old 11-09-2009, 06:37 PM   #1 (permalink)
Favourite Bike: 96 Adventurer
worldspeaker's Avatar
Blowing fuses for instrument panel, ideas?
Found myself riding my 96 Adventurer at night without instrument lights. Checked the bulbs and found two of the four burned out. Replaced all with LED's. Look great! I also found the fuse had blown. Replaced the fuse and all worked fine, for a little while. After a few minutes the fuse blows again. Nothing had been done to the bike prior to the first blown fuse. I realize I might be starting the nightmare of trying to find a short in the wiring. I am looking for suggestions. Is there anything else that could be causing this? If it is a short is there a place it normally happens on these bikes? Thanks for your suggestions.
Dave
Dave
worldspeaker is offline   Reply With Quote
Old 11-09-2009, 06:44 PM   #2 (permalink)
Favourite Bike: my 1999 triumph legend
ssevy's Avatar
Most likely you have a wire which has rubbed through the insulation where it goes into the back of the headlight housing. The wiring harness has been known to chafe at this location, and it is a matter of carefully pulling the loom out and looking for bare spots. I find electrician's tape to be a pain to use in wire bundles, so I use this:
You can find it at most hardware stores. It is also great for treating the ends of bootlaces so they don't fray.
ssevy is offline   Reply With Quote
Old 11-09-2009, 07:04 PM   #3 (permalink)
Thanks, that is where I will start my search.
Dave
Old 11-09-2009, 07:08 PM   #4 (permalink)
Favourite Bike: 2001 Triumph Thunderbird
Shadowofleaves's Avatar
Other Motorcycle: 1977 Triumph Bonneville
+1 on the headlight housing. Mt 2001 T-bird was popping a fuse every time I flipped on the high beam. As a result, my instrument panel and Tach went dead each time the fuse blew. My headlight housing was disassembled but no bare wire was ever found. The whole thing was re-assembled and I haven't had a problem with the fuse box since. I guess that pulling the wires loose to inspect them sort of "corrected" whatever problem was going on in there.
Shadowofleaves is offline   Reply With Quote
Old 11-11-2009, 07:23 AM   #5 (permalink)
Favourite Bike: '99 Triumph Legend "The Green Wonderbike"
BigAl8295's Avatar
You may also want to check the housing on the license plate housing. I had water getting into mine, causing a short, and blowing that same fuse.
FCR-39 Carbs, Sprint Cams, British Customs Predator Exhaust, K&N Pod Filters, Nology Coils, Ignitech Ignitor, Progressive Fork Springs, ZX-6R shock, and one bad ass Horn Cover!
Charm City Mods vs Rockers Rally
BigAl8295 is offline   Reply With Quote
Old 11-11-2009, 11:46 PM   #6 (permalink)
the worst part about electrical issues is sometimes you are not really sure if you fixed anything. I started looking into all the suggestions and found that the wire coming from the taillights (thanks Big Al for sending me that direction) had been really crimped under the seat. I had moved wires in the headlight but did not "see" any bare wires that could be arcing. I then uncrimped the taillight wire and put in a new fuse and rode for 50 miles. So far no issues. Don't feel like I really fixed anything but it seems to work. Instruments work and so do taillights. The only issue now is the brake lights do not come on with the rear brake. They are fine with the front brake but not the back. I appreciate all the suggestions. Need to figure out the rear brake situation and then I think I am good to go. Here in Socal we can ride all year but a lot of it is in the dark. Thanks again for all your help.
Dave
Dave
Old 11-15-2009, 07:20 PM   #7 (permalink)
Administrator
Favourite Bike: '98 Triumph Thunderbird
Tbirdnz's Avatar
Other Motorcycle: '05 Honda CB1300
Originally Posted by worldspeaker View Post
........ The only issue now is the brake lights do not come on with the rear brake. They are fine with the front brake but not the back..............Dave
Wow 3 days and no reply, we must be all on holiday !
Follow the rear-brake arm and find the small electrical connection to the switch which has electrical wires out of it to the rear light. Check that area first, could be a faulty. The switch itself is hydraulic so if you have to replace the switch you will need to bleed the brakes but check the wiring to it first.
Ride on !
Tbirdnz is offline   Reply With Quote
instrument panel blinking and fuse blowing italialaw Daytona Deliberations 13 10-29-2009 06:11 PM
blowing fuses sandblaster Hinckley Classic Triples 19 12-11-2006 06:04 PM
Blowing fuses PolockJoe Twins Talk 2 10-03-2006 05:09 PM
S4 blowing fuses sangsters Triumph SuperSports 6 09-28-2005 06:13 PM
Fuses blowing sangsters Maintenance & Workshop Talk 6 09-27-2005 10:19 AM
