Chelmi92,
The TBS shock is a straightforward fit. I didn't bother changing the plastic tray on the rear fender to secure the TBS unit remote reservoir, as it doesn't move around when the seat is fitted.
My TBird is a '04 model - one of the last, but it has been modified a bit - with a TBS engine, Daytona wheels etc. See the attached picture.
The ride height is about 25mm higher than the standard Tbird - just like the TBS. I didn't change the dog bones as I wanted more height as it makes it much easier to put the bike on the centre stand.
I kept the stock TBird sidestand, but I had already added about 15mm to the length of the side stand as even without the extra length of the TBS shock, I thought the bike leaned over too far when parked.
I just drilled a couple of small holes in the stand base and bolted a piece of hardwood to the base. This was meant to be a temporary fix until I got around to welding a piece of steel to the stand, but it works OK so I left it alone. You can just about see the extra part of the stand in the picture.
If you do lengthen the stand, you need to make sure that the bike can still lean over far enough in the event that you have a puncture! Hope this helps.
