Originally Posted by buckoz
thanks for the link
it should flow much better than the original i have often thought that with the feed on the carbs in between 2 the third carb would be a bit leaner so i am going to put a T peice in between the other 2 and run another T to the tap so all carbs will have the same amount of fuel at the same time
Sandy at Triumphant (in Wales) advises that mod when adding performance upgrades, cams etc, so maybe no bad idea. (He's done a lot of upgraded Classic Triple engines.)
