Remounting Engine in 95 Tbird after clutch repair - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismSportbikeTrackGearHonda PowersportsMotorcycle.com Classifieds!
Old 11-05-2009, 07:27 PM   #1 (permalink)
Favourite Bike: 2009 Bonneville T100
TheBigMaroon's Avatar
Other Motorcycle: 1995 Thunderbird 900
Extra Motorcycle: 1999 Thunderbird 900
Need some help with suggestions for remounting the engine of a 95 Tbird after repairing the sprag clutch. We're trying to follow the instructions in the workshop manual which recommend attaching the front bolts first and then jacking the engine into place to attach the rear bolts, however the rear bolts aren't lining up properly.
Does anyone have any suggestions for hoisting the engine into proper position?
Is it possible the the frame may have shifted after the engine was removed? The reason I ask is that it appears that the engine is getting hung up on one of the rear mounts when we're trying to get it back in place.
Any thoughts or suggestions are appreciated.
Thanks.
Mike
TheBigMaroon is offline   Reply With Quote
Old 11-06-2009, 03:57 AM   #2 (permalink)
Favourite Bike: Daybird
faffi's Avatar
Other Motorcycle: StreetTracker project
Hooking up the front bolts first is the way to go. Most likely, the problem you have at the rear is because of the swingarm/suspension thingos. Before fitting the engine, make sure that the wheel is under exactly the right load/in position that at least the lower or uppr bolts will line up perfectly. From there on, it's a piece of cake
If it ain't broken, rip it apart and find out why!
faffi is offline   Reply With Quote
Old 11-06-2009, 02:42 PM   #3 (permalink)
Slinky's Avatar
The rear plates can move around once the bolts are out, that's probably what is catching you out.You may have to jiggle them around as you lift the engine into place.
Triumph clutch setup/repair/adjustment videos Plewsy Vintage Technical Tips & Tricks 52 09-16-2010 10:05 AM
1996 sprint 900 starter clutch repair churches67 T3 Sport / Touring Forum 3 01-12-2009 08:09 AM
Rear Wheel Remounting Problem: II Mancha Twins Technical Talk 8 03-20-2007 10:29 PM
Clutch repair - 1972 bonnie 4 speed T120R twlynch Classic, Vintage & Veteran 29 01-23-2007 10:44 AM
remounting clocks and headlights to turn with forks? lromoda Speed Triple Forum 4 01-04-2006 08:20 PM
