6 speed - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comOntario TourismHonda PowersportsSportbikeTrackGear
Old 11-04-2009, 04:29 AM   #1 (permalink)
Favourite Bike: 1999 legend
buckoz's Avatar
6 speed
hey ya can you guys tell me what years had 6 speed want to by a 6 speed to put in my 99 legend
cheers buck
sun comes up sun goes down when that stops then we worry
buckoz is offline   Reply With Quote
Old 11-04-2009, 04:44 AM   #2 (permalink)
Favourite Bike: Daybird
faffi's Avatar
Other Motorcycle: StreetTracker project
AFAIK, you can get the sixth cogs from any 6-gear T300 (Daytona, Sprint) etc. along with the shifting forks and fit to your existing tranny. Personally, I wouldn't bother - the difference between 5th and 6th gear is rather small as it's a close ratio gearbox. But then I'm a lazy and thend to leave it alone if it works
If it ain't broken, rip it apart and find out why!
faffi is offline   Reply With Quote
Old 11-04-2009, 04:51 AM   #3 (permalink)
Muzz Bird98's Avatar
Hey Buck, No knothing about 6th gear but some info here
http://moe27.tripod.com/6gear.htm
Or just rev it more, geeze 5000 in 5th is getting quick for me and still have 3000 left
cheers
Murray
Muzz Bird98 is offline   Reply With Quote
Old 11-04-2009, 08:06 AM   #4 (permalink)
Favourite Bike: '99 Legend / '98 TBS
BigAl8295's Avatar
It's possible to swap or even add the gear to your current transmission because there's a spacer where the 6th gear should be.
I've thought about it, but the gain is NOT worth the aggravation.
FCR-39 Carbs, Sprint Cams, British Customs Predator Exhaust, K&N Pod Filters, Nology Coils, Ignitech Ignitor, Progressive Fork Springs, ZX-6R shock, and one bad ass Horn Cover!
Charm City Mods vs Rockers Rally
BigAl8295 is online now   Reply With Quote
Old 11-04-2009, 08:25 AM   #5 (permalink)
faffi's Avatar
I contemplated changing the oil sump from my TB engine over to the Daytona engine I use (due to not wanting the Daytona oil cooler) but having seen the amount of seals that needed replacing when opening the bottom, I decided it was a much better idea to simply by the bypass pipe from the Trident and fit instead
I'd never bother to fit a 6th gear unless I had the engine open already. And probably not even then. However, different people have different ideas of what they think is fun or not, and I cannot hold it against those who enjoy tinkering.
Old 11-04-2009, 11:57 AM   #6 (permalink)
Vendors
Favourite Bike: T'bird
jaguartvr's Avatar
Other Motorcycle: wide glide
Extra Motorcycle: T140v
bypass pipe
Faffi, do you know the part number, or from what years the bypass pipe comes from.
I have a Trophy that has been turned into a T-bird and want to lose the oil cooler.
jaguartvr is offline   Reply With Quote
Old 11-04-2009, 02:08 PM   #7 (permalink)
buckoz's Avatar
thanks murray might be cheaper to by a whole second hand gearbox than pay what we do here for new parts
thanks guys
Old 11-04-2009, 06:26 PM   #8 (permalink)
faffi's Avatar
Sorry, no part number, but the 91-93 Trident 900 definitely has it. It was likely fitted to early Sprints as well. Was cheap, too; about £25-30 in this cost inflated country.
Old 11-08-2009, 01:05 PM   #9 (permalink)
Favourite Bike: t.bird 900, not 1600!
f r o s t y's Avatar
I had 5 and 6 speed t.bird, no big differences founded, I wouldn't have changed if knew it before.
f r o s t y is offline   Reply With Quote
Old 11-10-2009, 04:46 AM   #10 (permalink)
thanks guys
Why not tinker with the drive and rear sprocket sizes.
Ist gear is always enough to get you rolling.
Murray
2001 Speed Triple or 2003 speed four???? TheBigCat Speed Triple Forum 8 04-26-2010 05:31 AM
Speed Four to Speed triple, good choice? Reppyboyo Speed Triple Forum 15 04-17-2009 06:57 PM
Speed Triple Gauges (Top Speed) posse Speed Triple Forum 9 05-15-2008 08:39 AM
1995 Speed Triple 6 speed box Tycho Maintenance & Workshop Talk 31 09-13-2003 02:12 PM
