Are any of the other triumph speedo units a bolt on replacement for the TB/TBS?. I'm starting another bike build, and don't have a set of clocks for the bike......I was wondering if anyone had fitted the bonneville or another model of speedo or speedo/tacho combination?
Thanks for the reply...............I will need some clocks, as I don't have any for the bike I'm building............so I wanted to see what people had fitted, or what could be fitted............It seems that there may be a few to go at :-)
Got a set of Trophy clocks all in the pod that I removed to fit T-bird clocks, so they should swap back. I'll hang onto them for to have a look at for when you come down.
