I'd talk to a dealer, tell them what you removed. The drag link pivot bolt is an M12x119 torx head, I think - but check with the dealer to be sure - and you will need the locknut, too, presumably. Best if you can look at the dealer's fiche for the rear suspension to identify what you removed and what you didn't. The centre stand would have had sleeves/bushes that fit inside its two pivot arms - if they are the bushes you say you removed (they are only needed with the stand fitted, obviously) then the sleeve and roller bearing that runs through the drag link should still be in place. If not, then you will need to replace them, and I think there are a couple of seals in there, too.
