cleaning forks without explosion
chemists out there... on my tbird the old rubber grommets that hold the headlight mounting tubes off the forks have deteriorated badly, turning the rubber into an extremely sticky mess that i'm anticipating having some trouble removing. my question is, as traces of whatever i use may mix with the fork oil, what is safe to use? turps? methylated spirits? petrol? i doubt fork oil would cut through it. acetone? kerosene? organic stain remover (made from oranges)? answers based on experience are preferred over best guesses, as i am concerned that fork oil may be like brake fluid - a possible ingredient in homemade explosives if mixed with the wrong thing. don't really want to blow my handle bars through the shed roof.
