You could also weaken the stock lever so that it breaks in a fall, rather than the shaft breaking. That is the problem, the lever is stronger than the shaft.
Today I drilled a line of holes in mine, hopefully enough to weaken it so that it becomes the sacrificial part if the bike ever goes down.
