Clutch Drag
My 1996 T-bird has suffered from clutch drag for about a year. Finally, I opened things up and found that all the friction plates, steel plates, and inner and outer baskets were in "new" condition. Amazing with 42,000 miles.
Suspecting a master or slave cylinder issue, I measured the pressure plate throw which was a mere 2 mm. With about 17 discs, I was expecting maybe a 5 mm throw distance. Unfortunately the manual does not give specs for this.
Anybody know for sure what the throw measurement should be at the pressure plate?
Thanks much.
