Time to change chain and sprockets - need some advice - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsMotorcycle.com
Old 10-20-2009, 02:30 AM   #1 (permalink)
Favourite Bike: 2000' T-bird sport
Ksound's Avatar
Other Motorcycle: None
Extra Motorcycle: None
It's time to change the chain and sprockets. I've read on here that most of you like an 18 on the front. My dealer recommended a 45 on the back with the 18 front sprocket. I'm looking for more snap off the line and more power. Would this setup do the trick? What are your experiences?
And if this is repetitive please guide me to a thread.
thanks
Ksound is offline   Reply With Quote
Old 10-20-2009, 02:46 AM   #2 (permalink)
Favourite Bike: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '06 Husqvarna TE 610
Extra Motorcycle: '95 TBird - Project
45/18 = 2.5
43/17 = 2.53 - Stock
The 2.5 or 2.53 means the countershaft turns that many revolutions every time the rear turns one revolution.
The higher the number the more acceleration off the line.
So the 18 - 45 will not give you more off the line.
I have 18 - 45 on both my bikes. I like that except it requires a 116 link chain and that puts the wheel back pretty far in the swingarm, thus increasing the wheelbase a bit (maybe 1/2" - 3/4"). A larger rear would move the wheel forward.
I used the 18 front because I wanted to minimize the wear on the rubber block that protects the swingarm.
If you use an 18 on the front you'll need to go with a 46, 47, or 48 on the rear to get better snap off the line.
PM me your email address and I'll send you a copy of the gearing spreadsheet that will tell you what Revs you'll have in each gear at various speeds. You'll need MS Excel to use it.
Cheers,Denny
denny is offline   Reply With Quote
Old 10-20-2009, 04:11 AM   #3 (permalink)
Favourite Bike: 1999 legend
buckoz's Avatar
spot on denny i went 18-41 because i do a lot of highway miles do loose a little punch out of corners on the mountain twistys but low revs on the hway
sun comes up sun goes down when that stops then we worry
buckoz is offline   Reply With Quote
Advice Please. - chain and sprockets lovecuba Hinckley Classic Triples 12 01-14-2008 05:22 PM
Shop to change sprockets & chain oldyeller Daytona Deliberations 3 08-10-2007 10:27 AM
Should chain change mean sprockets too? black-bonnie Twins Talk 9 09-28-2006 01:54 PM
Life time of sprockets and chain?? TheStig Sprint Forum 6 07-05-2006 11:32 AM
Chain/Sprockets one more time Maintenance & Workshop Talk 6 04-22-2005 01:03 AM
