Old 06-21-2005   #1 (permalink)
i'm very angry over this so i won't go into details but the very tip of my shifter shaft has broken off. i have already taken the clutch out and what not and i know i will have to go in through the sump to get this out. i guess what i am wondering is can i avoid replacing the shaft somehow? i've been waiting to order some raask rearsets and i was wondering if the the linkage would fit on whats left of the shaft.
camaromullet is offline   Reply With Quote
Old 06-21-2005   #2 (permalink)
Cafe Racin' Moderator
Favorite Bike: 1996 Thunderbird - Nessie
cafetbird's Avatar
Other Motorcycle: 1973 Triumph TR7RV
Extra Motorcycle: 1968 Bridgestone 350 GTR
It's possible to make a fix. Particularly if you are going to rear sets, you may never need to replace the shaft!
Since the shaft is only case hardenend, you can center drill what remains of the shaft if you are handy (and careful). Get the hardest industrial drill bit you can find, and you need at least 3-5 full threads to get this to hold. Then gently tap this hole (make sure you use the correct size drill for the tap), and use a cap screw w/ washer to hold the shift linkage in place. Using some red Loctite will help set the screw.
Don't feel so bad, I have broken mine shaft end off twice. I used this fix both times until I could get around to replacing the shaft - the first time it held for 1 full year. After the second drop, I installed frame sliders....
[ This message was edited by: cafetbird on 2005-06-21 21:16 ]
Scot Dail, IBA #31553
Pack Member, Charlotte RAT
cafetbird is online now   Reply With Quote
Old 06-21-2005   #3 (permalink)
you don't have any pics do you???
Old 06-21-2005   #4 (permalink)
cafetbird's Avatar
Man, I don't know where to start looking for them, but I'll see!
Scot
Re. broken shift shaft on Legend Trumpnut Hinckley Classic Triples 18 05-18-2007 03:22 PM
Gettn the shaft!! Breaking the shift! FourHorsemen Twins Technical Talk 11 06-30-2006 10:13 PM
The Final Solution TrackerOldGuy Speed Triple Forum 9 06-07-2006 09:13 AM
T'bird gear shift shaft oil seal Tbird900 Hinckley Classic Triples 3 05-14-2006 05:17 PM
Solution for the 2-3 Shift hang FALSTEN Hinckley Classic Triples 4 05-03-2004 02:43 PM
