Motorcycle.com
Old 02-07-2004   #1 (permalink)
Now I've done it...
Was trying to take off my airbox and one of the band clamps that fasten the airbox to the carb was really tight... and you guessed it, stripped it out good.
It's kind of a tight squeeze up in there, so it's very difficult to get a grip on it with pliers or channel locks, plus there's not much turning room either. I tried putting in the next size up (it WAS a 3mm) and I can't back it up well enough to tap in the oversized one (I doubt it'll work anyway: it is really, really tight!)
This all started because I've been having a fuel leak somewhere (I think) aroudn where the fuel line connects to the carbs. If anyone else has had this problem, I'd be interested in talking to you.
Any suggestions at all? :???:
Old 02-07-2004   #2 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
I suggest that with the tank removed you use a dremel or hacksaw blade and carefully cut through the band - they shouldnt bee too expensive to replace as they are essentially just cheap hose clips.
Mick...
size of front wheel axil/spindle allen bolt 2000 st? stwanted Sprint Forum 4 03-20-2007 05:33 PM
Stripped flywheel bolt & oil tube valiantbultaco Classic, Vintage & Veteran 1 03-14-2007 01:02 PM
Stripped bolt or busted nutsert on TOR exhaust retrograde Hinckley Classic Triples 5 11-03-2005 10:00 PM
stripped head Classic, Vintage & Veteran 4 01-17-2005 07:58 PM
Stripped out allen head bolt Modifications & Workshop Talk 4 02-07-2004 07:50 PM
