Head Bearing Spanner 38mm thin. - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Old 08-23-2009, 12:13 PM   #1 (permalink)
R0B
Main Motorcycle: 2004 790 Bonnie
Other Motorcycle: scrambler with sidecar
Extra Motorcycle: BMW R1150RT
Anyone know of a cheaper source than Triumph for a thin 38mm spanner to adjust the head stock bearings?
Thanks
Rob
R0B is offline   Reply With Quote
Old 08-23-2009, 03:03 PM   #2 (permalink)
Slinky's Avatar
A hammer and drift?
Seriously, taper roller adjustment only needs to be hand tight, all you have to do is lock it off.
IrlMike had some spanners made up, he may still have some.
Old 08-23-2009, 03:42 PM   #3 (permalink)
R0B
I was just trying to be 'sensitive'..........rather than my usual lump hammer approach. . I'll drop mike a line.
Thanks
Rob
Old 08-23-2009, 04:46 PM   #4 (permalink)
Main Motorcycle: Well, Duh!
MickMaguire's Avatar
Originally Posted by Slinky View Post
A hammer and drift?
But the lock is fairly critical - this is not something you want working loose (i.e. you want to make sure the locknut is tightened to spec.). Hammer and drift would be a last resort to me
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 08-23-2009, 05:13 PM   #5 (permalink)
R0B
Just for info Irlmike doesn't have any spanners left.............bugger
Cheers
Rob
Old 08-23-2009, 05:14 PM   #6 (permalink)
Main Motorcycle: 99 Legend Sprint GT
IrlMike's Avatar
I've none left, but I just found the old thread. It was Beemie who was considering getting some made in the US. I sent him the dimensions etc. Not sure if he went ahead?
98 Tbird tank/seat, Sprint fairing, ZX7R forks+Racetech Gold Valves, 08 ZX6R shock, Alcon 6-pot, Ignitech+TPS, T'bike 3-1+Beowolf can, airbox mods/rejet, tubeless wheels, lots :) per mile.
IrlMike is offline   Reply With Quote
Old 08-23-2009, 09:49 PM   #7 (permalink)
Main Motorcycle: 03 TBird
Beemie's Avatar
Other Motorcycle: '76 Bonnie
I'll get back on it and see how much the fabricator will charge to make some.
Beemie is offline   Reply With Quote
Old 08-24-2009, 03:59 PM   #8 (permalink)
Main Motorcycle: Me Thunderbird of course
Other Motorcycle: Toyota Landcruiser
Extra Motorcycle: IT 490
Make them yourself. Not really hard with oxy gear and a good steel rule.
I believe there is no such thing as accidents. When I ride I must leave enough room for others stupid mistakes, added to that is enough room to make my own.
WoodsieIII is offline   Reply With Quote
Old 08-24-2009, 05:48 PM   #9 (permalink)
Main Motorcycle: my 1999 triumph legend
ssevy's Avatar
If someone will send me the dimensions, my brother-in-law is a machinist, and maybe he could knock a few off.
ssevy is offline   Reply With Quote
Old 08-24-2009, 06:00 PM   #10 (permalink)
Main Motorcycle: 2003 Sprint ST
Other Motorcycle: 2004 Ducati 999S
Extra Motorcycle: 1974 Norton Commando S3
Before you try to make them yourself, you might look at what is available for professional bicycle tools. I believe there are some very thin wrenches commonly used on bicycles, but it has been quite a while since I was building them. Also, of course, Motion Pro makes specialized motorcycle tools that are readily available via the Web.
I was thinking of a headset wrench for a bicycle; unfortunately 38 mm doesn't seem to be a standard size.
The people who talk the most generally have the smallest results. Results speak for themselves. - Matt Mladin
Coroja is offline   Reply With Quote
Steering head spanner / tool IrlMike Hinckley Classic Triples 16 04-09-2009 01:37 PM
head bearing adjustment BornAgain Twins Technical Talk 4 08-17-2008 10:10 PM
Head Stock Bearing Tool Prestimp Speed Triple Forum 1 04-26-2007 11:16 PM
Help please - Steering head bearing gavinb Sprint Forum 8 11-25-2006 03:23 PM
Head Bearing Issue fivehundo Daytona Deliberations 5 06-22-2006 12:58 PM
