Expected behavior of temperature warning control light - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 06-13-2005, 03:42 PM   #1 (permalink)
tordan58
Hi all
(This is my first posting on this forum)
I have a question related to the expected behavior of the temperature control light on the Thunderbird 2002.
After a while, either when standing still in traffic jams or when driving long times at low speed, the water cooling fan will eventually start -- which is perfectly normal. However, the unusual thing is that the red control lamp will turn on. More precisely, shortly before the fan starts it will sort of flash with reduced light intensity and as the fan starts, it turns on completely. Once the fan has cooled the engine enough and turns off, the light will go back to flashing mode and after a short while it will turn off.
So question is: have anybody here experienced this weird behavior? Is the lamp a functional one, or is it a warning lamp (which it is according to the instruction manual)? Is the wiring incorrect? Any clues?
Tord
Sweden
Old 06-13-2005, 04:09 PM   #2 (permalink)
This seems to be a pretty common occurrence on the TBird. IIRC, it can be fixed by running an additional ground?
I am sure someone who has resolved it will pipe up but I don't believe it is anything to be too concerned about.
Trumpets4Years is offline   Reply With Quote
Old 06-13-2005, 04:21 PM   #3 (permalink)
Favourite Bike: 1996 Thunderbird "Nessie"
cafetbird's Avatar
Other Motorcycle: 1973 Trump TR7RV "Loosie"
Extra Motorcycle: 1968 BS 350 GTR "Smokie"
Here is a recent thread on this - there is a link to the factory fix included.
temp light
Scot Dail, IBA #31553; 59 Club #29906
"Thunderbirds are GOOOOOOOO!"
Old 06-13-2005, 05:08 PM   #4 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
If it only does it just before the fan cuts in dont bother with the service bulletin fix which while it may fix this problem also was really intended to fix related issues of it coming on with blinkers/brake light etc.
My Tbird has done this since new, but as it goes off again right away as the fan cuts in I just ignore it.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 06-14-2005, 09:07 AM   #5 (permalink)
Favourite Bike: The one I'm on
Other Motorcycle: 2006 Sprint ST ABS
Extra Motorcycle: 2000 Thunderbird
I've never seen the temp light on my bird in over 33,000 miles.
Could you see me if I was standing on your hood kicking in your windshield?
upNorth is offline   Reply With Quote
Old 06-14-2005, 09:19 AM   #6 (permalink)
Favourite Bike: My TBS of course
zimtok's Avatar
I had this very problem...
But because it was not a major problem I waited untill I had to remove the fuel tank for something else and then I did go ahead and add a ground wire from the battery to the grounding point on the main frame.
That was two years ago and I haven't seen the temp light come on since.
Like Mick says, the ground may help this problem but the bulletin was to correct problems with the lighting.
I remember someone saying it was mostly due to the set point of the fan being close to the set point of the temp light sending unit.
I don't know for sure but the ground wire seemed to solve my temp light problem.
My life is based on a true story.
www.throttlejockey.co.uk
zimtok is offline   Reply With Quote
Old 06-14-2005, 09:30 AM   #7 (permalink)
cafetbird's Avatar
I think it is a matter of personal preference. I am with you Mick (my 'Bird does the same as yours, with almost 50k now), but some folks are so *nal that this little glitch would drive them completely insane... ;-)
Old 06-14-2005, 09:44 AM   #8 (permalink)
Same as Mick :-g and Scot :-g
[ This message was edited by: legend21 on 2005-06-14 07:44 ]
legend21 is offline   Reply With Quote
Old 06-15-2005, 09:28 AM   #9 (permalink)
zimtok's Avatar
Some are anal about this and would do it right away once they found out about it.
I looked at all of the discussions and determined that this was not serious and it could wait for the next time I had the tank removed. It was about 6 months before I had the tank off again and decided to add the ground. I wasn't even expecting it to make a difference. But it did, and if adding this ground corrected this problem then maybe it prevented another problem from happening.
I have seen many problems in cars because of a bad ground. Some minor and some major.
If it doesn't bother you that you might have a ground problem then don't do anything about it. Maybe nothing will happen. But does it hurt that I added the extra ground? I don't think so. And I feel better because I did.
Tordan58, read the informaiton and decide what you want to do. It is your bike.
:chug:
Old 06-16-2005, 04:22 PM   #10 (permalink)
cafetbird's Avatar
Zimtok makes a good point - current is not flowing through your system the way it should, and could lead to a pre-mature failure?
Intermittent Fault - Engine warning light & Fuel light Tassie_Tiger Tiger Chat 4 06-13-2006 09:58 AM
Engine light and erattic low fuel warning light guy71 Daytona Deliberations 12 04-17-2006 09:18 AM
Temperature light always on, as soon as contact is on? Julien_Paris Trophy 5 10-27-2005 05:10 AM
Temperature warning light Livestrong Speed Triple Forum 0 08-26-2005 10:20 PM
Temperature light problem vonbonds Hinckley Classic Triples 4 07-12-2004 02:34 PM
