06-10-2005, 09:52 PM
anyone ever put a speed triple engine into a legend or thunderbird or ever hear of someone doing so? i'm pretty sure it will work but i don't know if it will mount to the frame the same way.
06-10-2005, 11:04 PM
Site Supporter Pole Position Favourite Bike: 1996 Thunderbird "Nessie"
Posts: 3,563 Other Motorcycle: 1973 Trump TR7RV "Loosie" Extra Motorcycle: 1968 BS 350 GTR "Smokie"
Yep, it's been done. Should mount right up, but you might have to make a few minor mods.... I am assuming you are talking about the 885 engine? A T-5 might be a bit more challenging.
[ This message was edited by: cafetbird on 2005-06-10 21:06 ]
06-10-2005, 11:22 PM
actually i think its the 955, but the mounting looks the same.
06-12-2005, 10:50 AM
Seen it with the 855.Looked killer!
06-12-2005, 01:28 PM
Moto Grand Prix Favourite Bike: 1995 S3
Posts: 2,672 Other Motorcycle: 1995 Sprint (cal) WC only
It would be nice to mount a 955 into a t300 frame, whether it be a TBird, S3...., but I think the engine is shorter and the mounts somewhat different in position consequentially. I have seen a Fi to Carb conversion for the 955 engine in a race bike back in the late 90's, which might be a better choice than trying to ram the airbox etc... into zero space, 'cos of the centre spline frame. At the time it produced more power than the Fi, go figure! But engine size, mount position would be only a hiccup to the determined - recently 955 engines on ebay have been going for $500 or so. :hammer: :hammer: :hammer: :-D
06-12-2005, 07:45 PM
Would a Tiger engine be a better choice since it doesn't use a perimeter frame?
2000 TBS Cafe Racer :: 2000 Frankenmille
06-12-2005, 09:47 PM
i know i just missed the one on ebay for $386, ***** it. if i could make it work, it would be sick.
06-12-2005, 10:21 PM
Site Supporter Pole Position Favourite Bike: Well, Duh!
Posts: 3,650 Other Motorcycle: Can't afford two! Extra Motorcycle: Three would be insane
Well you saved yourself some money in all likelihood, the dimensions and mounting point locations are different (as already said) but also the inlets are angled upwards at 45 degrees so the carbs wouldnt fit, and also the exhaust headers are a totally different shape at the cylinder head joint.
If you want speed triple spec, the best thing to do is to rengineer the engine cases to take the 955 pistons and liners, then upgrade your head to speed triple/daytona spec.
Lots of work but it can (and has) been done.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
06-13-2005, 09:54 AM
PS. your Legend's frame was not designed to handle 115hp. Get on the gas hard and it will start flexing.
06-13-2005, 10:35 AM
Actually the frame should be good. what is essentailly the same frame handles 147hp in the Daytona 1200. However, the brakes, wheels and suspension are not designed for all that extra power and would likely give problems (or worse be dangerous).
[ This message was edited by: MickMaguire on 2005-06-13 08:36 ]
Mick...
