Popping on Decel - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGear
Old 07-28-2009, 10:19 PM   #1 (permalink)
Popping on Decel
Thanks to everyone for the help so far. So I installed emgo shorties on my 98 TBS. Had some popping and back firing on decel. Removed the carbs to set the mixture screws they were set at 3.25 turns out. So I adjusted to 2.5 and the popping got worse. Set the carbs back to 3.25 and the popping is worse than before I touched the screws. Could the air box or rubbers between the carbs and air box be leaking? What should my next step be? Thanks again.
mynock03 is offline   Reply With Quote
Old 07-28-2009, 10:49 PM   #2 (permalink)
Main Motorcycle: 98 Adventurer
Other Motorcycle: 1980 kz 650 kawasaki
Extra Motorcycle: 1999 kaw Concours
Conventional thought on that is if you are more than 31/4 to 3/12 turns on the pilot screws you need to go one step larger on the pilot jet and then try setting the screws.
Bbogie is offline   Reply With Quote
Popping during decel oregonthruxton Twins Technical Talk 11 03-15-2007 03:44 PM
popping on decel, good or bad? typhoo Club Cafe' 26 03-05-2007 02:09 PM
Popping on decel with TOR cans on 04 S3 roller Speed Triple Forum 6 06-07-2006 08:13 AM
Popping during decel PolockJoe Twins Talk 17 04-13-2006 10:30 PM
'02 - '04 Sprint Decel Popping? cafetbird Sprint Forum 7 04-04-2006 02:31 AM
