Antifreeze - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-06-2005, 02:08 AM   #1 (permalink)
Having trouble finding motorcycle specific antifreeze here in New Zealand, most of the motorcycle dealers seem to use antifreeze designed for automotive use, or just corrosion inhibitors (for offroad use).
Some of these auto products claim to offer good aluminium protection, anticavitation etc, for up 250,000 km. Should I use one of these? or should I try and get the right stuff? :???:
BillBo is offline   Reply With Quote
Old 06-06-2005, 08:17 AM   #2 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
Automotive is fine, so long as you drain and flush the system first. You also need to make sure you get one that is silicate and phosphate free.
[ This message was edited by: MickMaguire on 2005-06-06 06:20 ]
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 06-07-2005, 11:19 PM   #3 (permalink)
Favourite Bike: 1995 Thunderbird
SWare's Avatar
The orange stuff like GM Dexcool is phosphate free. Says do right on the bottle.
I think most of the green antifreeze contains phosphates. Could be some that don't but it should say on the labeling.
stan
SWare is offline   Reply With Quote
Old 06-08-2005, 11:22 AM   #4 (permalink)
Favourite Bike: Favourite Bike
Dexcool is defective and has been killing the engines it's been installed in for years. I highly suggest you avoid it.
http://www.cwcd.com/CM/ClassActions/ClassActions35.asp
Avatar is offline   Reply With Quote
Old 06-08-2005, 12:35 PM   #5 (permalink)
Does the silicate & phosphate work together to damage the engine ? How does phosphate hurt the cooling system does it pit the aluminum or something ? What does Triumph put in the radiators at the factory ?
Opinions are like armpits everybody has a couple & they usually stink
vwvectors is offline   Reply With Quote
Old 06-08-2005, 11:05 PM   #6 (permalink)
Favourite Bike: 2003 Speed Triple
Other Motorcycle: 1999 Legend
Oh,Great! I just put Dex-cool in both my bikes like 3 months ago. Guess I'll have to change it out ASAP
No quarter asked, none given
Gdsila is offline   Reply With Quote
Old 06-08-2005, 11:09 PM   #7 (permalink)
Favourite Bike: 03 TBird
Beemie's Avatar
Other Motorcycle: OIF Bonnie
Before you panic, do a search on corvetteforum about Dexcool.
I believe that issues arise if you Mix with conventional. Something about turning to sludge.
Neither my Vette nor Tahoe have spilled their guts, and there was no recall.
[ This message was edited by: Beemie on 2005-06-08 21:12 ]
Beemie is offline   Reply With Quote
Old 06-09-2005, 02:38 AM   #8 (permalink)
Thats part of the problem, most manufacturers of auto antifreeze don't mention what it does or does'nt contain (apart from the base is usually ethylene glycol)
Old 06-09-2005, 06:46 AM   #9 (permalink)
Hey Beemie, thanks for the comforting words! I am leaving for Americade in a few hours and was kinda freaking a bit.
When I changed the coolant I didn't really "flush" the system that well but I dont think what was left in the bike(of the old coolant) is enough to cause any adverse reaction.
P.S. I was sorta thinking of switching to "Engine Ice" for the Speed Triple anyway the S3 is known to run a bit hot ,and Engine Ice is supposed to be for race applications.
Old 06-09-2005, 09:43 AM   #10 (permalink)
I've been using dexcool for over a year with no problems. Those that are silicate and phosphate free usually say so, those that aren't usually dont say anything. From what I hear the problem is that these compounds affect the seals in the water pump.
I am pretty sure that you dont get sludge if you mix dexcool with the blue Triumph premix as I dont recall any warnings about compatibility (other than silicates and phosphates) for top-up in the manual. But I shoudl point out I have never actually tried it! I think some reports of this may be confusion with the red coolants that some manufacturers like VW uses (are these related to engine ice perchance?), they will sludge up if you mix them with regular anti freeze.
[ This message was edited by: MickMaguire on 2005-06-09 07:44 ]
Mick...
Where did my antifreeze go? Maintenance & Workshop Talk 11 07-17-2007 10:28 PM
Antifreeze Bluetiger901 Maintenance & Workshop Talk 2 03-18-2007 11:40 PM
Antifreeze question rew7602 Tiger Workshop (archive) 1 01-13-2007 04:10 AM
Antifreeze? SaddleTramp Sprint Forum 5 10-27-2005 03:08 PM
new s4 leaking antifreeze Triumph SuperSports 12 10-31-2003 09:07 PM
