Site Supporter Pole Position Favourite Bike: Well, Duh!
Posts: 3,650 Other Motorcycle: Can't afford two! Extra Motorcycle: Three would be insane
Do not
repeat
Do not undo those bolts that hold the muffler to its mounting bracket. They will not help you here and you are almost guaranteed to have one of them break loose mid removal with the result that you will have a bolt stuck half way out and flopping around
Do remove the clamps, unbolt the rear hanger bracket from the subframe / remove the rear pegs. Now use a rubber hammer around the join t to the headers and even on the muffler hanging bracket to persuade it to start to move. Persevere and you will get the two to separate. It may help to get the pipes warm by running the bike for a little while before you start. Alternatively you may want to try removing the mufflers complete with the headers as a unit then dismantling once off the bike.
The 98/99 TBS pipes are the hardest to get apart IMO but you will get there
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
