handle bar risers
Hi
did a long trip early this year with camping gear etc. Used a tank bag which was okay, except when I turned a corner the indicator cancel switch hit the bag and turned off the indicators. Was thinking of installing risers (maybe 50 mm) to get the indication switch up out of the way. Has anyone put these on a T-bird? If so, did you have to replace the cables, brake lines etc? If it's too much of a hassle I'll either go to 35 or 25 mm or forget it all together.
thanks
andre12a
