2000 Adventurer Chain & Sprockets? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-08-2009, 10:42 PM   #1 (permalink)
Favourite Bike: 2000 Adventurer
eelmgren's Avatar
One thing missing from my Haynes book-
Can anyone tell me the number of teeth on the stock sprockets and the chain length on a 2000 Adventurer?
eelmgren is online now   Reply With Quote
Old 06-09-2009, 04:04 AM   #2 (permalink)
Favourite Bike: Me Thunderbird of course
Other Motorcycle: Toyota Landcruiser
Extra Motorcycle: IT 490
The bike bandit will be able to tell you, from memory the Thunderbird sprockets are 17/43 teeth and the chain is 114 links. Please check though as the Adventurer may be different and my memory has been faulty before. Edit, I had the chain length wrong
I believe there is no such thing as accidents. When I ride I must leave enough room for others stupid mistakes, added to that is enough room to make my own.
WoodsieIII is offline   Reply With Quote
Old 06-09-2009, 10:52 AM   #3 (permalink)
Favourite Bike: my 1999 triumph legend
ssevy's Avatar
You might want to consider going up one tooth on the front sprocket. I went from a 17 to an 18 on my Legend, and I think it places the revs in the power band better.
ssevy is offline   Reply With Quote
Old 06-10-2009, 02:12 PM   #4 (permalink)
Newbie
Hello there, I'm writing from Italy and my english is not perfect.
I wouldn't change a 17 teeth sprocket for a 18 on an Adventurer, because the total diameter (rim+tyre) of the rear wheel is much longer on Adveturer and T-bird (with 160/80 tyre) than on Legend:
in fact there is a difference of 19 mm.
And I can assure you it's a noticeable difference, I tried on my Legend both wheels and the overall gear ratio was higher (correct, in my opinion) with the 16' rim and 160/80 tyre.
A 18 teeth sprocket is a good idea on Legend, not on Adventurer.
Cristian is offline   Reply With Quote
Old 06-10-2009, 03:13 PM   #5 (permalink)
ssevy's Avatar
Great point! I overlooked the tire size difference. Sorry for the brain fart!
Old 06-11-2009, 04:42 PM   #6 (permalink)
eelmgren's Avatar
I've done a bit more research since I first posted. Both Bike Bandit and JT Sprockets show an 18T front and 43T rear as stock for this bike. I think the earlier models may have had the 17T. Do others have something different?
Old 06-11-2009, 11:29 PM   #7 (permalink)
Favourite Bike: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '06 Husqvarna TE 610
Extra Motorcycle: '95 TBird - Project
My parts book shows Adventurer from VIN 71699 and up use the 18 before that they used the 17.
Cheers,Denny
denny is offline   Reply With Quote
New chain & sprockets 2000 Adventurer- how to? yodink Hinckley Classic Triples 5 08-25-2009 02:34 PM
Replace Chain and sprockets, still have a tight spot in chain toecutter Sprint Forum 10 05-28-2009 12:07 PM
Want to put a centerstand on a 2000 Adventurer carsandcigars Hinckley Classic Triples 1 03-08-2009 07:06 AM
2000 Adventurer utecityrat Hinckley Classic Triples 1 05-13-2008 10:20 PM
What is the sprk gap for a 2000 Adventurer? Msullivan Hinckley Classic Triples 4 05-01-2004 07:40 PM
