Supersport 600 Favourite Bike: 02 Thunderbird
Headlight went out, what happened?
So I've been riding with a range rover (or rather, cheap RR knockoff) headlamp for about a month, with no worries. Sometimes, as I did with the OEM headlamp, I'd accidentally stick it into highbeam without noticing for a few miles... This becomes relevant soon.
So, leaving from a friend's house towards home, a few blocks from the highway (11PM), I hit the pass switch to get some quickie high-beam love on the pavement. Everything's fine... and then poof, no highbeam. Releasing the pass switch, no low-beam either.
Still lit was the tiny bulb below the main bulb; I've heard it called a primer bulb, lord knows why? All it told me was that something there was still getting juice, but it sure didn't illuminate anything ahead of me usefully.
I pull over, shut the bike off, turn it back on - it fires up fine, but the headlamp's still out. And oddly, so's the tach; the lights on the tach are still lit (ditto for the speedo), but the needle isn't moving. Nor are the indicator lights (temp, oil, flashers). The flashers themselves work, but I don't see it indicated, if that makes sense.
Well, as I'm miles from anywhere, I head home - in the dark - sans headlight. Slowly, with hazards on. Much of the ride home is highway...
Nearer home (after perhaps a half-hour of normal riding performance, lack of tach & headlight aside), I get off the highway. After a few blocks, the bike decides that two cylinders is better than three, and acts on this (I'm basing this on sound / feel / power to the wheel). At stops, I have to keep it revved up to not die; and I need to be revving higher than normal to start moving.
At two blocks from my house, it seems to take another step in this direction; is it even possible to run on a single cylinder? This felt like what was happening; I suddenly had to rev much higher to get moving & not die, and still ended up dying numerous times.
Through bullheadedness I got it home and parked; I pulled the seat, and went through the fuses one by one (why I didn't do this originally, I don't know; inborn stupidity? Live & learn), and the last one (if you're at the rear of the bike looking towards the bike, the far right fuse) was blown; it's a 10-amper. In the dark, I couldn't read the legend as to what it's for. I had a spare, replaced it, and started the bike - and up she fires, headlight going strong, engine realizing the joys of three cylinders firing, neutral light shining, tach needle happily jogging its way towards 3.5krpm on full choke. I switch to brights, no worries, there's the brights. I flick the pass switch, hey, there's brights again.
So what happened? And how did a fuse blowing cause a delayed-reaction cylinder-by-cylinder orderly shutdown? I'm a tad freaked out about it.
