Ignition lock removal - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 06-07-2009, 01:30 PM   #1 (permalink)
R0B
Favourite Bike: '95 TBS special
Other Motorcycle: '99 Tbird being built
Extra Motorcycle: '97 sprint sport
I'm just taking my top yoke off for polishing. How do I remove the ignition/steering lock-it appears to have a security bolt.
Thanks
Rob
R0B is offline   Reply With Quote
Old 06-07-2009, 03:53 PM   #2 (permalink)
Favourite Bike: Triumph Legend
Yes they are fitted using snap off bolts. For reasons of security
There are many ideas on how to remove these bolts, it's not too difficult.
buxtonmick is offline   Reply With Quote
Old 06-07-2009, 04:21 PM   #3 (permalink)
Favourite Bike: My 98 TBS
Other Motorcycle: 83 Honda XL 250
Easy solution:
Use a dremel and cut a slot in them then use a flat tip to back them out. When you put it back together you can use the same dremel to file down the slot to restore the security feature if you wish.
blackfly911 is offline   Reply With Quote
Old 06-07-2009, 04:36 PM   #4 (permalink)
Favourite Bike: T'bird/Trophy hybrid
Other Motorcycle: Toad King
Extra Motorcycle: XS650 Yam
drill
The other way is to drill the heads off the screws, remove the switch then use a pair of needle nosed mole grips to remove the bits of stud left behind.
This is not a course of action for the faint-hearted, or the mechanically challenged.
If the drill wanders off, it will munt the switch housing, being made of cast cheese.
You need to do it on a pillar drill having ACCURATELY centre-punched the screws first.
Ask me how I know!
When you put the switch back, don't use security bolts unless you is livin' on de front line, mon. Use ordinary screws.
2 wheels good 3 better is offline   Reply With Quote
Old 06-07-2009, 05:28 PM   #5 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
if you remove the tank and forks, turn the triples to the far right or left and it will lift off without taking the lock off the triple.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 06-07-2009, 06:39 PM   #6 (permalink)
R0B
Thanks for the replies. I thought that I might use an end mill to cut the head of the bolt off, but I thought I might as well check here first. I will certainly not replce them with the factory bolts. if anyone nicks my bike, i'm sure it won't make a bit of difference.
Hi Mick, I need to actually remove the lock for polishing........I already did the 'wiggle'
thanks all
Rob
Removing Ignition Lock & Other Questions... KitNYC Sprint Forum 9 04-09-2009 01:25 AM
Stupid question about Ignition & column lock key ramble59 Twins Technical Talk 14 07-18-2008 06:57 PM
Ignition lock (cylinder) wire connector gatortiger Maintenance & Workshop Talk 6 01-08-2007 12:32 PM
Loose Ignition / steering lock Parky Tiger Workshop (archive) 5 10-03-2006 12:48 PM
H/d/I remove the ignition lock? TxDave Maintenance & Workshop Talk 5 06-13-2005 11:13 AM
