Site Supporter Pole Position Favourite Bike: Well, Duh!
Posts: 3,650 Other Motorcycle: Can't afford two! Extra Motorcycle: Three would be insane
good diagnosis if you are sure it came from the airbox not the petcock.
Time to clean out the float bowls, and mesh filters. while you are in there inspect the float valves for wear.
small particles of rust and debris can make it through the filters on these bikes (you will probably find red powder in your float bowls). A better inline filter can help to eliminate this.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
