Speedo Swap - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!New BonnevilleOntario TourismMotorcycle.com
Old 06-04-2009, 11:33 AM   #1 (permalink)
Newbie
Speedo Swap
Anyone know if I can use a speedo from a 2000+ Bonneville on my 99 Tbird?
What's the technique for removing the trip counter stem from the speedo in order to remove the speedo from the case?
malagodi is offline   Reply With Quote
Old 06-04-2009, 11:39 AM   #2 (permalink)
Favourite Bike: my 1999 triumph legend
ssevy's Avatar
Can't answer the first, but as for the second, on my 99 Legend, it was just a friction fit and pulled off with some careful prying. Others have said they had a small screw holding it on, but mine did not.
ssevy is offline   Reply With Quote
Old 06-04-2009, 02:07 PM   #3 (permalink)
Slinky's Avatar
You probably will be ok using a Bonneville speedo. Manufacturers tend to stick to one ratio for the head, and adjust the speed by using different speedo drive gears.
2002 Bonneville Speedo swap 02T-MAN Twins Technical Talk 2 04-19-2009 11:48 AM
Speedo repairs Hinckley Speedo bon Twins Talk 0 01-11-2009 04:41 PM
America Speedo Swap Raven Twins Technical Talk 2 10-25-2008 01:49 PM
Figuring out the Speedo ratio-using alternate speedo clamp007 Twins Technical Talk 0 05-04-2007 02:15 AM
heallight/speedo swap DirtMcGirt Speed Triple Forum 1 01-10-2007 01:28 PM
