Hydraulic Systems Seals & Pistons Replacement? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-03-2009, 10:03 PM   #1 (permalink)
Favourite Bike: 03 TBird
Beemie's Avatar
Other Motorcycle: OIF Bonnie
The manual says to replace the clutch and brake system seals, which would include the piston assemblies, every 2 years.
Does everyone do that?
All the parts involved would be a small fortune, maybe even midium sized.
Beemie is offline   Reply With Quote
Old 06-03-2009, 10:20 PM   #2 (permalink)
Favourite Bike: 1999 T'Bird Sport
lovecuba's Avatar
Other Motorcycle: 2001 Sprint ST
Extra Motorcycle: 1977 T140
Hydraulic Seals/Pistons
I believe, in this case, that the advice given in the manual is for 'purists'.
The seals rarely give out suddenly as they are not under huge pressures. Gradual wearing is the order of the day and some seepage will generally occur to indicate wear. If this is noticed promptly then seals only should be required. The pistons will need replacing if deep score marks are evident on them.
lovecuba is offline   Reply With Quote
Old 06-03-2009, 11:52 PM   #3 (permalink)
ClassiclyMobile's Avatar
I replace the fluids every 2 years and wait for seals to fail. No failures in 10 years.
ClassiclyMobile is offline   Reply With Quote
Old 06-04-2009, 12:17 AM   #4 (permalink)
Beemie's Avatar
Since my Bonneville master cylinder seals lasted almost 30 years I was a bit skeptical about the recommendations for the triple.
I guess if I had changed the brake fluid in those 30 years the cylinder might not have corroded and the seals wouldn't have failed.
I'm doing better with the Thunderbird, but I'll be really surprised if I make it another 30 years without retiring to a scooter.
Old 06-04-2009, 11:32 AM   #5 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
are you sure - I dont have my manual here - but I would have sworn it was fluid every 2 and seals and hoses every 5.
From what I have seen here most people don't change them, and dont have any issues caused by not. Over on the T3 forums I see guys changing them for the first time on pre-95 bikes for the first time.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 06-04-2009, 12:02 PM   #6 (permalink)
Favourite Bike: 2005 Rocket III
Bobby K's Avatar
Other Motorcycle: 1973 Triumph Tiger
Extra Motorcycle: 1995 Triumph Thunderbird
I have a 95 Bird. Rebuilt the front MC last year (leaking) using a 2003 Honda Shadow Spirit kit. (Can't remember where I got that tip). I see that my clutch MC is in need of attention now, those parts will have to come from Triumph.
Bobby K is offline   Reply With Quote
Old 06-04-2009, 01:25 PM   #7 (permalink)
Beemie's Avatar
The factory workshop manual says 2 years for both services.
Unfortunately it looks like the master cylinder "seals" are part of the piston assembly and perhaps not separate items.
So multiply $50-$80 times the number of pistons, and considering each end of the brake and clutch lines, it accounts for quite a bit of money.
Old 06-04-2009, 01:32 PM   #8 (permalink)
2 years is un-necessarily low in my opinion - heck my bike was that old when it left the dealership!
I will have to look out my factory service checklist sheet - I feel like that may be where I got the 5 years from.
Mick...
Old 06-04-2009, 02:04 PM   #9 (permalink)
Favourite Bike: my 1999 triumph legend
ssevy's Avatar
The biggest enemy to seals is water in the hydraulic system. Once corrosion and rust begin to appear, they create an abrasive surface in the cylinders which the seals begin to rub upon. Doesn't take long to wear through a seal like this. If you change out your fluids annually, the water has no chance to cause corrosion, and your seals are only moving in an environment of nice slippery brake fluid. Since catastrophic failure is highly unlikely without seeing some seepage as a prior warning, I wouldn't worry at all about them. If you are changing your fluids yearly, you may never see this at all. I have rebuilt car master cylinders in the past, and usually if they are leaking, the cylinder is already pitted to the extent that the whole unit needs replacing. It isn't often that a seal kit will make a lasting repair once the corrosion has begun, even if you then put in fresh fluid.
ssevy is offline   Reply With Quote
Old 06-05-2009, 05:33 PM   #10 (permalink)
Favourite Bike: 1996 Adventurer
Other Motorcycle: 2000 DRZ400-S
Extra Motorcycle: '99 Ninja 250,'04 KDX200
Interesting! I need to rebuild my front caliper and master cylinder as well. Where did you purchase this kit? Was it a Honda kit? Do you happen to have the part #?
Thanks!
gregp is offline   Reply With Quote
Hydraulic Clutch 7873jake Classic, Vintage & Veteran 15 05-05-2009 07:11 AM
Hydraulic Clutch sanscrainte Speed Triple Forum 7 09-12-2007 03:49 PM
Hydraulic Workbench COOPERS Classic, Vintage & Veteran 2 03-01-2006 05:41 PM
Hydraulic clutch? iansoady Tiger Mods & Bolt-Ons (archive) 3 09-26-2005 03:28 AM
hydraulic clutch stHelen Speed Triple Forum 2 04-11-2005 12:37 PM
