Valve shim question - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.com Classifieds!New BonnevilleMotorcycle.com
Old 06-03-2009, 04:43 PM   #1 (permalink)
Favourite Bike: 96 Bird
Other Motorcycle: 97 BMW R850R
Extra Motorcycle: 71 Bonnie
Valve shim question
ok..the bird is on the lift, the valve cover is off, I have the tool , and it all looks pretty straightforward..however , my clearance should check .004 to .006 for my intake valves (0.10 to 0.15 for you metric folks)..and my exhaust valve clearance should check .006 to .008 (0.15 to .20)..wich boils down to a total of .003 total range.....my question is how come the valve shims only come in increments of .002 (.05)...?? ..so lets say i check any clearance and find it on the low limit (tight)...i can only replace the shim with one that is smaller by .002 ..so then my tolerance would be on the high limit (loose) I really would not be any better off would I?...does anybody know of a source of valve shims that come in increments of .001 (.025) so I can put it "spot on" ....hmmm..i think ill have a frosty one and think a while on it....i havent made any checks yet, i just ran out of time......cheers...............Tom
its not leaking oil!!...its marking its spot!!!
tnsen is offline   Reply With Quote
Old 06-03-2009, 05:12 PM   #2 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
Thats absolutely fine - in fact as a rule if you have a choice tend high (greater clearance).
they make them in twos so they dont have to make so many difference sizes / charge you more.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 06-03-2009, 06:03 PM   #3 (permalink)
Favourite Bike: Triumph Legend
Shim sizes
Check out a Yamaha dealer - the shims from the place that I use increment by .025 (metric of course).
buxtonmick is offline   Reply With Quote
Old 06-03-2009, 09:50 PM   #4 (permalink)
Interesting the shim kits we had at our shop back in the UK only used to go in .05 increments - maybe times have changed
Mick...
Old 06-08-2009, 08:59 PM   #5 (permalink)
thankx for the replies...i finelly took the time to get the shims out and i was surprised to see 3 place decimals, meaning they were stamped 2.625,... 2.725...ect... i thought they were going to be 2.65 or 2.70..and such....i am sure they are stock, as i am the 2nd owner....this means they are in increments of .025(.001) ... not .05(.002) as i thought....Tom
Old 06-09-2009, 03:06 PM   #6 (permalink)
Favourite Bike: '99 ThunderLegendSprint
IrlMike's Avatar
Other Motorcycle: Wouldn't mind a Tiger 800
Extra Motorcycle: Can't ride more'n one...
Yes, I have bought .025 increments from Triumph too.
Legend chassis, Tbird tank/seat, Sprint fairing, tubeless wheels, Thunderbike 3-1, air box mods, 115/40 jets, DJ needles, Ignitech with TPS, ZX6R shock, ZX7R USD forks/yokes, Alcon 6 pot
IrlMike is offline   Reply With Quote
Old 07-22-2009, 11:59 AM   #7 (permalink)
Favourite Bike: Triumph Thunderbird 2001
RandyRick's Avatar
Other Motorcycle: Yamaha Venture MM 2000
Extra Motorcycle: Suzuki DR200 2006
I'm geeting ready to buy a K&L Shim kit and a few extra shims in sizes most likely needed.
So. Having not torn into my Tbird yet, what sizes are people finding they 1. have and 2 need most often in the Tbird engines?
I'll go ahead and order a few spares of likely sizes.
My Yamaha also uses 25mm shims so, this is a double use kit.
Randy R.
RandyRick is offline   Reply With Quote
Old 07-22-2009, 04:17 PM   #8 (permalink)
IrlMike's Avatar
My Legend has one adjustment made (at 9k miles) & the fitted shims now range from from 2.55 to 2.80. There's quite a few sizes in there, considering you may need more than one of each, tho' it's usually possible to re-use a number of the ones fitted already into a different valve position.
Classic triple forum shim bank/exchange anyone?
Old 07-22-2009, 10:43 PM   #9 (permalink)
RandyRick's Avatar
I would make this kit available to forum members once I have it together.
The kit contains 2 ea of 2.30, 2.40, 2.50, 2.55, 2.60, 2.70, 2.80, 2.90, 3.00, 3.10
I think I will order 1 more 2.50, 2.55 and 2.60, 3 2.65's, and 2-2.75's
Randy R.
Old 07-22-2009, 11:12 PM   #10 (permalink)
Had a funny thing happen the last time I checked mine. I had 2 out of spec, and the shim I pulled from one valve was the exact size I needed for the other, and vice versa. So I didn't have to buy any shims. I have NEVER had that happen before. I've used some that I had on hand from previous adjustments, but never had that happen before.
wagonboss is offline   Reply With Quote
Valve Shim Question Tom Herold Maintenance & Workshop Talk 5 05-26-2008 06:10 PM
valve shim tool 955 malc Tiger Workshop (archive) 9 09-27-2006 12:20 PM
Valve Shim Needs? ssjones Twins Talk 6 01-08-2006 08:26 PM
Valve shim check zimtok Hinckley Classic Triples 15 10-29-2004 05:19 PM
Valve shim check zimtok Maintenance & Workshop Talk 0 10-27-2004 10:47 AM
